Which freq to hold short on?
Discussion in 'Pilot-Controller Questions' started by BobDDuck, Sep 15, 2017.
  1. BobDDuck
    BobDDuck Gone whale watching...
    Sep 19, 2003
    14,745
    9,125
    Scenario...
    Given clearance to taxi from ground control which Included a runway hold short instruction for the active landing runway.
    We taxied to the hold short location. After clearing the last taxiway prior to the hold short location I switched over to tower frequency and we held short. After a minute tower called to ask if we were on their frequency and then then cleared us across the runway and told us to hold short of the takeoff runway (duh?). She then told me that I shouldn't have switched from the ground frequency.
    I have always been under the impression that the tower controller has to issue a clearance across an active runway. I looked through the .65 and the AIM and couldn't find anything conclusive one way or the other.
    Thoughts?
    This specific airport does a ton of things that are non standard, so I really don't know if they are right or not.
  2. BigZ
    BigZ Well-Known Member
    Nov 19, 2007
    1,111
    784
    I'd say if the clearance was to taxi to rwy 24 via A4, A, B hold short runway 30, it wouldnt occur to me to switch to tower holding short of 30 whether it was active or not
    gotWXdagain likes this.
  3. Jordan93
    Jordan93 Well-Known Member
    Oct 27, 2015
    669
    867
    I would have stayed on ground frequency. They probably would have cleared you to cross then told you monitor or contact tower.
  4. z987k
    z987k TeamANC
    Feb 3, 2010
    11,357
    7,035
    Depends on the airport. Some will never clear you to cross on ground. You'll switch to tower to cross and back to ground on the other side.
    Others will keep you on ground.
    If they don't tell you to switch, don't. That way you're always right.
  5. milleR
    milleR Well-Known Member
    Mar 11, 2008
    2,649
    2,892
    The AIM says to stay on ground until ready for departure, but like all things from the FAA actual procedures appear to be consistently inconsistent.
    4−3−14. Communications
    a. Pilots of departing aircraft should communicate with the control tower on the appropriate ground control/clearance delivery frequency prior to starting engines to receive engine start time, taxi and/or clearance information. Unless otherwise advised by the tower, remain on that frequency during taxiing and runup, then change to local control frequency when ready to request takeoff clearance.
    NOTE−
    Pilots are encouraged to monitor the local tower frequency as soon as practical consistent with other ATC requirements.
    REFERENCE−
    AIM, Paragraph 4−1−13 , Automatic Terminal Information Service (ATIS)
    b. The tower controller will consider that pilots of turbine−powered aircraft are ready for takeoff when they reach the runway or warm−up block unless advised otherwise.
    MidlifeFlyer likes this.
  6. NovemberEcho
    NovemberEcho Well-Known Member
    Jul 4, 2013
    4,239
    5,941
    Some towers find it easier to have local issue runway crossings because for whatever reason it is easier than the ground controller having to coordinate with the local controller to do it. But either way remain on your assigned frequency until told otherwise and if in doubt just ask.
    inigo88 and jynxyjoe like this.
  7. MidlifeFlyer
    MidlifeFlyer Well-Known Member
    May 17, 2003
    6,536
    1,321
    This. SOP, as @milleR quited from the AIM, is to remain on Ground until ready to go at the departure runway. ATC will tell you if they want you to do something different.
  8. ppragman
    ppragman Direct BOOKE
    Sep 15, 2007
    9,618
    3,498
    Lihue going off of 17? Because literally every time.
  9. Roger Roger
    Roger Roger Navajo Whisperer
    Sep 4, 2009
    7,897
    9,877
    And yet you know the ATC guys will make fun of pilots for bad phraseology...
  10. ppragman
    Sep 15, 2007
    9,618
    3,498
    "Heh, dude didn't even say 'fife' - whata noob."
    Acrofox, NovemberEcho and inigo88 like this.
  11. ASpilot2be
    ASpilot2be SF340 CA
    May 1, 2005
    14,749
    3,298
    At PDX we always just stay on ground frequency.
  12. BobDDuck
    Sep 19, 2003
    14,745
    9,125
    Yep.
    Ground expects you to switch to tower automatically there anyways. I've heard crews get yelled at for not switching over because tower was trying to reach them when they were still a few thousand feet from the runway end.
    Cessnaflyer likes this.
  13. Screaming_Emu
    Screaming_Emu You people
    May 29, 2002
    14,852
    16,935
    I just call on guard so that EVERYONE knows I’m ready.
    JeppUpdater, m77y, aviator147 and 7 others like this.
  14. ppragman
    Sep 15, 2007
    9,618
    3,498
    They're good people up in the cab there, lemme see if I can get the number for them. I used to call them all the time with weird medevac requests (like asking if they could pass on critical status to hcf).
    After a couple weeks worth of "weirdness" I just got the numbers for there, ITO, and MKK, and just figured out exactly what they wanted. Its not standard but so is Kauai.
    BobDDuck and Cessnaflyer like this.
  15. gotWXdagain
    gotWXdagain Highly Visible Member
    Jan 17, 2009
    3,338
    2,704
    If they want you to make the switch, then they're supposed to tell you to monitor tower.
  16. Kingairer
    Kingairer Well-Known Member
    Apr 27, 2002
    5,823
    2,634
    So you were holding short of a runway, that you expected to cross, enroute to another runway that you would depart?
    In that scenario I wouldn't have changed to tower without instruction to do so.
  17. av8tr1
    av8tr1 "Never tell me the odds!"
    Oct 4, 2014
    2,226
    1,635
    We just had this senario happen at PDX. 28L/10R was closed. Company pilot was told to hold short for North runways. Said pilot taxied up to South runways and held while switching to Tower. Then with 5 airplanes (I was #3 behind) holding behind our wayward pilot who was where they were supposed to be but on wrong frequency held up literally half the airport while ground tried to reach said pilot on everything but South tower freq for a good 5 - 10 mins.
  18. Cptnchia
    Cptnchia Well-Known Member
    May 16, 2007
    8,406
    9,922
    Just saw this unfold in Atlanta two weeks ago. A Netjet waiting to cross 26R to go to 26L switched to tower instead of staying on ground and caused some problems.
  19. Nark
    Nark Well-Known Member
    Jan 27, 2008
    3,971
    3,171
    My 2¢:
    99% of the airports that want us to switch to tower without stating it have a sign. SAN comes to mind.
    FLL, I can remember I preemptively switched, and tower called asking if we were on freq.
    ORD, well... never use ORD as an example of standard.
Share This Page
