When GPS going down is no longer a theory
Roger Roger
Paid to sleep, fly for fun
You can type in coordinates, tune DME/DME or order a pizza through the FMS, but you won’t even get that far. The manufacturer does not allow you to defer all of the GPS in this airplane (the CL30 & CL35 series). If you’re flying that model and affected by this, then you’re done. Don’t even bother starting the APU. Not all airframes are impacted, but a large number that have a specific part number installed.
The tail I was flying (CL30) is not equipped with the now known GPS component and therefore was immune to this, and as a result I was flying over the last couple days. Other model aircraft maybe flying because they have relief in the MEL, such as the CRJ or whatever if they’re allowed deferral of the GPS system.
Right but, why are you not allowed to defer? Is it connected to so many other systems that the jet is just un-dispatchable? If so that’s pretty screwed up.
CFI A&P
Exploring the world one toilet at a time.
Because the manufacturer doesn’t permit it. As much as I’d like to give you a better answer, I don’t know and frankly wasn’t concerned. Mine worked, so I flew but others in the fleet had an issue and it was a NO-GO.
Figuring out how it happened, how to fix it, and re-write the MEL is above my pay grade. I was ready to go back to the hotel if it didn’t boot up normally.
BobDDuck
Island Bus Driver
You can't defer it because it's not in the MMEL. Who knows what is is connected to, but the OEM decided it wasn't deferable... so it's not.
Roger Roger
Well no crap. :rolleyes:
You don’t think guys flying those planes maybe should be a little curious why the manufacturer deemed a loss of GPS to be so critical the plane can’t dispatch without it? Like maybe to have an idea what would happen if GPS was lost enroute? Not that that could happen, GPS failures and whatever other systems are connected that the manufacturer didn’t see fit to tell pilots about only happen on startup.
@Autothrust Blue , @ppragman , am I taking crazy pills or should people care about this?
Autothrust Blue
"I’d make a suggestion but you won’t listen”
I find most pilots have little in the way of curiosity, frankly.
Which is fine, to a point.
CFI A&P
I get what you’re saying, but in a situation like this - if the books say I need at least 1 funcitioning GPS and 0 are functioning - then I’m S.O.L. Especially with a programming problem such as this with the GPS/ FMS, it’s going to take someone from the manufacturer to figure that one out. In fact, before I did the first flight after this problem surfaced, I called a friend that was flying when it quit and got the rundown. Since my unit booted up fine, I was dispatched and flying while Rockwell Collins/ Bombardier/ Transport Canada/ FAA & our POI was still trying to fully understand the situation and come up with a solution. Like any other GPS failure, you start getting vectors until you get the VOR to VOR set up and tracking. Another make/ model aircraft can dispatch with 0 if following a specified procedure, but we don’t have said procedure. If we did, I know how that would work (DME/DME). It still has two engines, two wings, and gas in the tanks; so I know it will physically fly but it couldn’t because of paperwork.
MikeD
Administrator
Staff member
MEL stuff aside, can the INS/INU not operate independently of GPS with whatever acceptable drift component it would have, like INSs used to do before GPS ever existed? Or will it not work at all without it. That’s what I’m curious about....a technical question.
CoffeeIcePapers
Well-Hung Member
Yes, it will work without it. You can update your position using navaids. If you enable auto-tuning on the radio tuning units, it will automatically update itself.
MikeD
Administrator
Staff member
Yeah some of the older 737s have that feature. I’m guessing some of these newer planes either don’t have that, have it but aren’t authorized to rely on it, or don’t have any other non-GPS update capability? Hence why not allowed?
Autothrust Blue
Most CRJs are not equipped with inertial navigation, and as such are DME-DME only sans GPS.
CoffeeIcePapers
Well-Hung Member
Yeah, it depends on the exact components that were installed. It varies, even among aircraft that are the same type.
tbflyer
The only problem with that technique is that if there is no GPS position in the CL30 & CL35 series, then you’re grounded. The MEL requires at least 1 GPS and does not allow for using DME/DME for position locating.
That sucks, I know I’m the CRJ you can type in an airport code then copy the airport location to the pos init position, we can also fly dme/dme
CFI A&P
Which has been brought up several times while discussing this. “But on the ____, we can do (insert procedure or technique).” “That’s great, we don’t fly the CRJ and are restricted by a different MEL.”
We can enter LAT/LONG and create a waypoint all day, that’s how we insert ETPs into our route when Class II.
Even if it was deferrable, it would limit the capability of the aircraft. No Class II, no RNAV SIDS/ STARs/ approaches, it is tied into the EGPWS, so no mountainous airports... Handicapping the aircraft like that is a little bit of a problem when operating under 135.
ppragman
FLIPY FLAPS!
Where on God's Green Earth would you fly a CRJ under class 2 nav? The Carribean?
ppragman
FLIPY FLAPS!
People should be extremely concerned about why.
jtrain609
I'm a carnal, organic anagram.
YEAH, BUT!!!
