Unpublished hold programming in G1000/GNS530W
PK
Here it is direct from Garmin's 2014 Archer Cockpit Guide.
CREATING A USER-DEFINED HOLD AT AN ACTIVE FLIGHT PLAN WAYPOINT
1) Press the FPL Key to display the Active Flight Plan Page (MFD) or the Active
Flight Plan Window (PFD).
2) Press the FMS Knob to activate the cursor (not required on the PFD) and
turn the large FMS Knob to highlight the waypoint for the hold.
3) Press the MENU Key, highlight ‘Hold At Wpt’, and press the ENT Key. The
HOLD AT window appears with the course field highlighted.
4) Use the FMS Knobs to edit the entry course, and press the ENT Key.
5) Use the small FMS Knob to select ‘INBOUND’ or ‘OUTBOUND’ course
direction, and press the ENT Key.
6) Use the small FMS Knob to select ‘TIME’ or ‘DIST’ length mode, and press
the ENT Key.
7) Use the FMS Knobs to edit the length, and press the ENT Key.
8) Use the small FMS Knob to select ‘RIGHT’ or ‘LEFT’ turn direction, and
press the ENT Key.
9) Use the FMS Knobs to edit the Expect Further Clearance Time (EFC TIME),
10) Press the ENT Key while ‘LOAD?’ is highlighted to add the hold into the
flight plan.
Garmin G1000 Cockpit Reference Guide for the Piper PA-28-181 Archer 190-01460-00 Rev. A
I've used it recently, it's not very intuitive, a lot of students spend 10 minutes programming it when it takes 2 seconds to mentally do it.
MidlifeFlyer
Shoot I had to ask for the published hold at BKA the other day...they told me to hold on my inbound awaiting approach clearance and I was like WTF?
I don't understand. Were you WTF'ing because you were given a hold or because you were given a simple non-published one?
MidlifeFlyer
In 3k plus hours of part 91 flying I have never been issued a non published hold
The only hold I've been given in more than 20 years (but a lot less hours than you) was a non-published hold. It was to KSAF which is below ABQ radar and I was instructed to hold to wait for departing traffic to clear the area. It was a simple VOR hold on the airway I was already inbound on.
I remember it not only because it was the only one but because the clearance was so short: "Hold southeast of the SAF VOR. Expect further clearance at ####Z"
Roger Roger
Paid to sleep, fly for fun
Because I was given a non published one at the IAF which has a holding pattern procedure turn. Had I executed their instructions, I would have had to hold unpublished until given approach clearance, then do the entry of the published hold to get set up for final, then shoot the approach. It would have been stupid. As it was I requested the published hold, received it, but slowed down enough that I was given approach clearance just prior to the VOR.
MidlifeFlyer
That makes sense. Context is everything. I thought it was a situation of, say, holding on the R180 at a IAF/FAF with 360° FAC, not holding on the R300 at the same VOR.
