• This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn more.
Tool storage and organization
Low&Slow
Kind of a slow last couple of weeks at work. The only aircraft work I did was replace a LH outboard windshield on a UH-60L, replace a LH upper window ("greenhouse window") on a UH-60M, and fabricate some shims so I could adjust a cargo door latch for a HH-60M.
So, I had some time to make a few things to improve my toolbox...
Small box for my microstop and an insert for the threaded piloted countersinks:
I can take the threaded piloted countersinks out for convenience if I want to. The two cut-off threaded drill bits on the end are just plugging the extra holes. They will get removed if I get more piloted countersinks. I have a row of standard 1/2" and a row of sliim 3/8".
Small box for the small diamond files:
The pockets each have a small piece of foam to firmly hold the file handles:
Unibit rack:
The 10-32 screws are threaded into the top plate, and the screw heads serve as feet. I cut 3/8" tubing down to 0.5" pieces to use as spacers. There are holes in both pieces (top and bottom) for the Unibit shanks:
Rack for my countersink bits:
It's very similar to my Unibit rack design, but I had to add a bottom plate because some of the countersinks had longer shanks:
Low&Slow
I also decided to store my drill bits vertically to minimize their footprint, so I found some tooling tubes, labeled them, and made a little rack:
