Piper Seminole
kdwilkes
For those at FSI or anyone who has flown the Seminole, do you feel like you are at a disadvantage training in that aircraft because it only has 180 horsepower as opposed to the Seneca or other light twins? It seems starnge that there are single-engine aircraft i.e. Cessna 182 that have more horsepower than the Seminole.
Secondly, do you ever get a high performance endorsement while training at FSI? If so, what aircraft? If not, is this a disadvantage?
Thanks again for your replies!
d_gelling
Keep in mind it has (2) 180 HP engines, not just one. FSI also has Seneca's on campus for training as well. Also, the Seminole is used by a substantial majority of flight schools for twin training and is pretty much the industry standard.
Yes you do get a HP endorsement. They have Arrows on campus and you also get spin recovery training in a Zlin acrobatic plane. I might be mistaken but I believe it has 300 HP and is supposed to be a blast to fly!
Baronman
He's right, the Seminole may be called the standard multi-engine trainer, although some do train in the Duchess ("The Dutch Ass") or the Seneca. I did my training in the Seminole and have since flown higher power aircraft like the Baron with little problem. HOWEVER, you DO NOT get a high performance sign off while at FSI. The Arrow and the Zlin both have the Lycoming I0-360 which is basically a fuel injected version of the 180 hp engine found in the Seminole and in the Archers and it produces 200hp. The Zlin engine has some special fuel/oil pumps for acrobatics. Note that the FARs state that a high performance aircraft has more than 200hp thus neither the Arrow or Zlin qualify. I happened to rent a plane and get my high performance sign off with an instructor I knew, all together it was just another lesson, nothing out of the ordinary.
