Part 135 destination with no IAP
jrh
Here's the scenario:
Part 135 turbojet operation.
Client wants to go to a destination several hundred miles away with no instrument approaches.
Operator has OpSpecs:
B050 which includes a limitation of "Turbojet VFR operations may be conducted only between airports within 100 nm of each other, at altitudes of less than 10,000 MSL and, except for takeoff and landing, not less than 3000 ft AGL."
C064 which says, in part, the operator is authorized to conduct flights in Class G airspace and to airports without an operating control tower, provided "The airport is served by an authorized instrument approach procedure."
C077 which essentially says flightcrew may operate VFR in the terminal area to uncontrolled airports, provided they can see the landing surface, etc.
Question now, can this trip be done legally? If so, how?
Inverted25
I would say yes. C064 wouldn’t apply because that is for operating IFR in glass G airspace. CO77 has a provision in there for canceling IFR for a VFR arrival. If the airport doesn’t have weather reporting they would need A057 Eligible on Demand. I could be wrong but that’s my quick take on it
Inverted25
Just double checked this and you can do it under CO77. My company actually goes to a couple airports with no published approaches. Look at C077 c. Terminal arrival VFR and section f. Special limitations and provisions for visual flight rules
jrh
This is why it seems like a gray area. Canceling IFR is certainly allowed under various circumstances.
What do you make of the requirement to have an IAP under C064? What circumstances would require the airport to have an IAP versus not? The way I read C064, it sounds like C064 applies to every untowered airport.
Inverted25
C064 would only apply if you were to stay IFR into the class G airspace. You would use C077 to cancel your IFR before entering Class G airspace making C064 non applicable.
jrh
I think you're right. As I re-read each OpSpec, this makes sense.
Seems kinda weird to be required to cancel rather than do a visual approach and keep the clearance down to the ground, but I think that's what the letter of the law says to do.
Inverted25
Yea there’s a few of those OpSpecs where it’s like I get the intent but your making it harder than it needs to be.
DesertNomad
Active Member
Land first at an airport within 100nm of the real destination that has an IAP and then depart for the one that does not?
That would satisfy B050.
CFIT99
I'm probably commenting ironically...
bingo! Coral Reef comes to mind...
