Ughhhhh I just threw up.Im gonna compromise tonight and spend whole flight in CWS mode.
I was out for nearly 2 years while I was sick and recovering. The handflying gets rusty, but honestly the flows were fine - I knew where everything was still. I hopped back into an airplane I had a fair bit of experience in and did not have a single issue other than I wasn't that smooth and my landings kind of sucked for a bit.Yeah, that is where we disagree. Sure, you need SOME practice. But honestly, not very much. Nowadays I only fly about 100 hours a year, at best. Sometimes I go three months between flights. The hand flying isn't what you lose. It's the flows and such. Hand flying after you've been flying for 20 years is like riding a bike. People just like to push it because it's an ego thing.
I handfly in good weather until I get bored. During approaches if it's VFR I'll handfly unless workload precludes it.As this comes up more frequently:
A few have mentioned that they like to hand fly - what is your threshold for when and when you will not hand fly (as in its busy and we need eyes out, don't want to overload the PM, or an ILS to mins)? Is it dictated by your SOP/FOM? Do you brief it or just do it?
I come from a school of 'do whatever you want, just don't screw it up' which I guess is fair but in terms of CRM does that make the it's your leg but I'm flying captains hover more?
Pretty much workload/weather/complexity/level of give a poop for me. If I'm with an FO I know really well or I can already tell they've got a good grasp on things I might hand fly up to 10,000 or 18. If it's a newer person that I can tell is barely hanging on by the tail I'll just click the thing on before 10 or so if it's super busy. Partly so they're not having to baby sit me, and partly so I can baby sit them as they fiddle with the box trying to get the thing to go direct 6 times. (Not a knock, but it can be tough for some of the new guys). If it's super choppy I don't find wrestling the flight director fun to make a level off either, autopilot comes on so I don't bust the altitude trying to look cool. Some departures are fun (TECKY out of SJC is fun to handfly), but honestly if I'm on a heading or direct a fix that's 50 miles away out of ORD cleared to 230 (where the autopilot has to be on anyway) I just click it on after a while. I figure holding 10 degrees of pitch in a straight line isn't necessarily honing any skills.As this comes up more frequently:
It’s been a long time but I’m pretty sure that is the procedure anyway.I think I might just start pulling random breakers to try to stop that.![]()
Every Mechanical Breakdown Requires An Electrical ResetApparently not:
NOTE: The aural warning can only be canceled by powering down the airplane.
I realize FAR compliance is for losers, but distracting, nuisance alerts must have a method for cancellation according to the current version of Part 25.Every Mechanical Breakdown Requires An Electrical Reset
When your CRJ 200 has the alignment of a 1995 mazda minivan that hasn't seen a mechanic in decades, the tiller allows you to provide equal input on the break pedals and therefore smoother stopping. But yeah it sometimes steers like a canoe, where you poke the paddle and then gauge the response.Guys that use the tiller on long straight taxiways make my head shake like a Bollywood star.
So, the Bus sucks. Glad we finally got that cleared up.This argument about automation. ATN, I agree with you that almost always if it screws up, it was the pilot operator error.
But my cases of hairy situations has been a case of being too close in to use automation effectively. Like coming in from the north to LAX, getting turned right into JETSA 2,200 ft. The vector is tight, approach mode is armed, and looks like it’ll capture but then invariably it gets the LOC, and GS is missed because of altitude capture. Plus they get task saturated slowing down, gear out, flaps.
Like Warren said, the automation doesn’t understand the word NOW! At this point , AP off and visually flying it works out better than trying to quickly smash buttons and turn knobs at the FAF.
Another thing specific to the Bus, you lose anything that takes you out of normal law, there goes your automation. Depending on the failure you may have some automation available / re-engages, but still you’re gonna be hand flying.
Anyway. I have enough time in the Bus now to be able to tell if the guy I’m with is weak without the AP.
In my experience, the guys who say the bus sucks fall into 3 categories:So, the Bus sucks. Glad we finally got that cleared up.![]()
I find that I subconsciously use more left brake. I don’t know if it’s due to me being left handed but I always seem to heat up the left side more than the right. Single engine taxi helps out a lot and I do it whenever I canWhen your CRJ 200 has the alignment of a 1995 mazda minivan that hasn't seen a mechanic in decades, the tiller allows you to provide equal input on the break pedals and therefore smoother stopping. But yeah it sometimes steers like a canoe, where you poke the paddle and then gauge the response.
Does anyone else have this issue? Braking evenly while one foot is pressed way forward to steer? and also when brake pads themselves are uneven that really screws things up.
No argument there. But I don't see any accidents or incidents being caused by people not knowing how to hand fly in this scenario, so I'm guessing most people are handling it just fine. Meanwhile, people don't know how to use their damned automation.ATN, you quoted me while I was editing the post.
I added this too:
Since I used to go into EWR and still go into SFO a lot, there are last second sidesteps for various reasons, usually they don’t have enough spacing. It’s a visual. You’re close to the ground. Here is where I’ll click click, click click. This isn’t the time to go heads down, reprogram the box, clean it up, and then get it coupled to the FD/AP. ***IF*** you have the time, sure. But it shouldn’t be the first move. Again, the automation doesn’t understand, “I need this now!”
