Engine Fire on Takeoff
troopernflight
Let’s say you have a left engine fire indication on the takeoff roll and you reject the takeoff. You don’t know at this point whether it is a true fire. As a precaution, you decide to initiate evacuation. Would you first call the FA’s on intercom to give instructions to evacuate and not to use the left wing or rear left emergency exits, or would you make a PA announcement to evacuate and give instructions over the PA?
BigZ
What does your manual tell you to do?
I'd probably do a PA "*code word to abandon ship x3* do not use left side unless verified safe"
Jordan93
Well I’d first run the engine fire checklist before I’d initiate and evacuation. Actually our manual says to run the RTO checklist, then the engine fire checklist.
troopernflight
We don’t have code words to indicate direction on evacuation. And this scenario is at the point when all previous checklists are complete, just evacuation.
Baronman
Run our rejected TO checklist which then *i think* sends us to the Engine Fire on the Ground checklist. At that point you're shutting things down and blowing bottles. Does the fire indication extinguish? Is there smoke in the cabin? No more fire and no smoke? Sit tight... Fire indication continues? Smoke in the cabin? Let's get out of here.
Rodger Wilco
After checklists are complete-
“Hey FAs, we have an indication for fire, what do you see, smell, hear???”
“Hey tower it’s flight 321 stopped on the runway. Say, how does our right engine look to you? Any smoke? The flight attendants don’t see smoke either but please roll the trucks just Incase, they can follow us to a hard stand.”
It’s always difficult to explain why grandma broke her hip jumping off the wing when all you had was a false indication.
Autothrust Blue
"I’d make a suggestion but you won’t listen”
Stop.
Parking brake on.
Flight attendants, stations.
Summon emergency equipment.
“I have control and ATC; ECAM actions.”
Run ECAM steps.
While that’s happening, see if the trucks see anything. If they do or if the fire indication persists, evacuation.
This is mostly scripted for us. Previous job was a lot more amorphous/freeform and I don’t consider that a positive.
Boots2Wings
Stop
Parking brake engage
Confirm fire or abnormality
Shutdown the engines
Extinguisher discharge if fire observed
Advice ATC and request trucks as necessary
Order evacuation as necessary
Battery Master/Gang Bar off
CA last to leave
Memory procedure for us
