Dreamliner - Sudden Failure of Both Engines on Runway.
thevideographer
Tell me more about how both the BA 777 and US Air 320 had engines seemingly shut down at the EXACT same time without any reason as to why... I'll wait.
BA 38 lost both engines due to heat exchanger issues and ice crystals. And are you really using US Air 1549 as an example of a dual engine loss?
Lets just ad the Gimli Glider to the list...
What does what language one speaks, have anything to do with anything?
Well, how about the Airbus A400M that had 3/4 engines at once go to idle thrust because of a software bug and crashed?
Inverted
#inspirationing
Software wipe mx error prior to the delivery flight.
Ok you guys are right. It’s totally common and plausible to have a part 25 airliner have the engines shut down prior to takeoff. I hate when that happens!!
ShortField
No one of consequence
After landing. Details n stuff.
fholbert
Both failing due to premature fatigue at the exact same time.......seems doubtful, though if I were that crew and that was actually what happened, I would go VFR direct to a casino and put everything on the table. Sounds like FOD or fuel exhaustion to me.
A friend of mine was a Captain on RR powered 787's. He says there is a Tech Bulletin on this very issue.
He was recently moved to GE powered 777's and is very happy on the 777 despite the older technology.
trafficinsight
Looks like the current target is software that shuts an engine down when a reverser deploys in flight...
Sent from my Moto Z (2) using Tapatalk
Skåning
By that metric, you're all hypocrites for laughing at the Wee Too Lo and Sum Ting Wong. Lighten up Francises!
And ANA isn't without its own bone headed incidents:
VIDEO: ANA 737 rolled near-inverted after rudder trim blunder
Japan's Transport Safety Board said the captain had stepped briefly out of the cockpit, but when he returned the co-pilot inadvertently operated the rudder trim control while attempting to let the captain back in.
The 737 banked slightly right, then twice rolled sharply to the left, achieving a bank angle of nearly 132° and "rapidly" pitching 35° nose-down, the inquiry board added.
It descended at high speed, losing 6,300ft before recovering at 34,700ft and climbing.
killbilly
That American 767 that was written off after a mx run at LAX...
One engine exploded and sent a turbine wheel out the side of the case which then deflected off of the ground and took out the other engine.
What are the odds?!
Greater than zero, apparently. :)
///AMG
What are the odds?!
hah.....fair enough. I've seen sympathetic failures in my jet (they are inches from each other), but I know there have been some similar transport category failures along those lines too historically. Touche
JeppUpdater
Whole lotta wtf in this one:
https://samchui.com/2019/01/19/ana-boeing-787-dual-engine-shutdown-upon-landing/#.XEPRwBqIahB
It’s worth noting that a bulletin was released by Boeing not so long ago to pilots and maintenance crew about the Thrust Control Malfunction Accommodation (TCMA) system, which prevents risk in an uncommanded high-thrust situation, stating that errors in the landing sequence could cause the system to activate. The errors include a combination of selecting full reverse too quickly before the aircraft has transitioned to ground mode followed by a quick deactivation of reverse thrust. Boeing advises not to apply full reverse too quickly in the bulletin.
bucksmith
Did you lock the doors?
That’s a bit of an overreach, I don’t recall laughing about that on a public forum. I’ve got nothing against offensive humor, but I’d give my buddy a discreet elbow in the ribs if he was loudly doing a bad accent while making fun of a different ethnic group in a public setting. (Or even if he’s making fun of his own ethnic group, despite not looking like he belongs to said group, ahem, you know who you are!)
But that’s just me.
