Departure Procedure Altitude
FL350
When flying this DP, towards PRB, must you be at 5,000’ before turning on that segment or just climbing to 5,000’ at 200’/nm
I’ve been flying RNAV SIDS with crossing restrictions at each fix, so this slips my mind now! Thanks for the advice
MidlifeFlyer
That is an MEA not an altitude restriction. But as the note says, the minimum climb rate is 275 FPNM to 1700 for obstruction clearance, then normal minimum 200 FPNM.
