Commuters Input Please
nyk
If one was to commute to work and would have the opportunity to have around 8-10 flights a day to your job and 8-10 back with zero connecting flights would you do it daily? Given: 10 hour shifts 4 days a week and the flight is only around hour one way.
Flying Saluki
When you factor check-in time, and transit between airport and work, a one hour flight quickly turns into a 3-hour (or more) commute each way. I would probably just commute once per week. And, I would probably drive. It might take a little longer than flying, but you have the convenience traveling on your own schedule.
TN-DX
How many flights are on company metal? How many prior to start or shift and how many after? Oh and city pairs too. That can make a huge difference.
azmedic
Is it for a regional job? If so,is it a route going to a legacy hub? If so,there is the potential for tons of commuters,even ones for the same company you work for. Like someone else said,either drive or commute in for the week and get a crashpad. A short commute like that can turn into a hassle quickly especially if WX/MX becomes an issue
nyk
One flight on company metal. Its GSO to ATL. I'm just really tired of moving.
The way I look at it is this. I don't want to move haha so I figured with that many flights a day it shouldn't be a problem commuting daily. I don't have a family or married but I'm just looking to stay put for awhile. The pay isn't going to be anything spectacular so why bother moving plus I just moved here in February and really don't have the energy to move again. Thanks for the input so far everyone.
F9DXER
I can totally understand the not wanting to move part.
It can be done daily. I knew someone that commuted daily between LAS and DEN. Like you he had no kids (to include 4 legged ones) or family at home so he didn't have to be there.
You are going to pay a cost by commuting. Time being the biggest one, also expect that you may have to spend money for a hotel/food at time.
Everyone is different when it comes to commuting so if it works for you - fine. But you will never know until you try.
LX Sport
I commute to Chicago from MSP....on average its atleast 3-4 hours each way. There are alot of flights between the two city pairs, considering Chicago has two airports that have flights to MSP, and its only an hour flight, I still would NEVER daily commute. That sounds like employment suicide. One cancelled flight can screw you over, one bad wx day can screw you over. It might be possible, but it seems like a stupid idea to me.
Get a crashpad and commute home on the weekends...like a normal airline employee :)
nyk
Thanks for calling me stupid :sarcasm:
That's Affirm
Has an Active Member
#13
If you like where you live try it out. I commuted to SKW in SGU from SLC for a year. Despite there being multiple flights on company metal from both SGU and CDC to SLC daily I found it easier to drive the 4hrs than take the 1hr flight simply because it was on my schedule and I got to maximized my time at home with the wifey. I did not do it daily though, only once every 4 days. I believe I would still be doing the same thing if I were at SKW today.
ChitownMike
I commute between Chicago and Indy every week for work but not daily. I've got a crash pad I share with a fellow dispatcher and its $400 a month including rent/bills. I also typically drive back and forth instead of flying as the hassle of airport parking and not always getting on the planned flight turns a 90 min ordeal into a few hours or as other posters have stated - cancelled or severely delayed flights.
Burrito
I'll ask the stupid questions
#16
Check your QOL, my man. If you're up for the commute and the risks therein, moving "just once more" may be the lesser of two evils.
This coming from someone doing PHL/DAY and drives 30 min during the 4-day on's for the crashpad.
All about your QOL.
Flagship_dxer
Legacy Airline Dispatcher
#17
Dont speak. Everytime you do I want to vomit.
He is right in a way. It will be a miserable experience trying to commute everyday from GSO-ATL. It is a stressful way to live your life. GSO-ATL has a decent amount of pilot commuters on it. Your own metal wont matter much if a pilot from your own company shows up. RDU is close and CLT a little further afield but all three are frequently full with jumpseaters to ATL. You dont want to have to bang in sick often because you missed your commuting flight.
On the return side, you will always be at the mercy of your relief showing up early, TSA lines, and the frequent long trips to the gate at ATL via walking/train.
Its a terrible idea and your blood pressure will likely go through the roof if you try it. Avoid the stress and get a crash pad.
If you are working at XJT, you can expect to be junior manned fairly often which will mean even more days you would need to commute back and forth.
If you are on the L-XJT side, you will not as of the last time I checked have DL benefits. This means you will be at the bottom of the priority for seats in the back on GSO-ATL if a pilot shows up.
PHL_Approach
I'm agree with mannix. It'll be a life lesson. Try it since you think it's a manageable daily commute. More than likely, you'll realize it's not a good idea after a bit. But the benefit of trying it out is it'll kick your butt into moving as fast as you possibly can. Good motivation for a move. So yes, give it a shot.
