What makes the vapor over a wing?
Discussion in 'Technical Talk' started by turbojet28, Jul 23, 2004.
  1. turbojet28
    turbojet28 Well-Known Member
    Dec 29, 2001
    516
    23
    Hey everyone,
    Just a quick question; many times you can see when an aircraft is taking off (and seen a lot on fighter jets when they do very steep/tight turns - sorry for the "non-technical" way of describing it /ubbthreads/images/graemlins/smile.gif ), there is condensation above the wing and off of the wingtips (almost in the vorticies). What exactly makes this? If I had to take an educated guess, it seems that it usually happens in flight conditions at high angles of attack (such as takeoff or tight turns while holding altitude), so my thoughts were that it is from Bernoulli's Law and when these high angles of attack are made at high speeds, the pressure lowers enogh to allow the air to cool to saturation and condensation. Is this correct? Thanks!
    P.S. - I would just "google" the subject, but its more fun to discuss it here! /ubbthreads/images/graemlins/cool.gif
  2. cime_sp
    cime_sp Well-Known Member
    Oct 22, 2002
    969
    44
    Correct. They are called contrails and are nothing more than condensed water vapor. The wing is creating it's most lift during takeoff or like you said during maneuvering flight and this causes a drop in pressure. That drop in pressure causes the air to cool and water vapor in the air to condense.
  3. Ralgha
    Ralgha Well-Known Member
    Dec 7, 2003
    1,135
    67
    Actually they're chemtrails, and they consist of various chemicals that we spray over the population to further government experiments and population control programs.
    We also have dark beam weapons that shoot out the front, but I'm not supposed to talk about those.
    Actually, you probably better forget you read this altogether.
  4. aloft
    aloft New Member
    Sep 5, 2001
    8,933
    4
    You are correct, sir. The same principle is at work in the formation of upslope fog and standing lenticular clouds.
    <--actually learned something from my IR Gleim book! /ubbthreads/images/graemlins/grin.gif
  5. aloft
    aloft New Member
    Sep 5, 2001
    8,933
    4
    Just stare at this light for a moment....*flash*
  6. kellwolf
    kellwolf Piece of Trash
    Jun 17, 2003
    21,929
    952
    Snoop Dogg has an IR?!??! Who knew. /ubbthreads/images/graemlins/smile.gif
  7. FalconCapt
    FalconCapt New Member
    Nov 25, 2003
    489
    0
    Exactly correct...
  8. PhilosopherPilot
    PhilosopherPilot Well-Known Member
    Jul 24, 2003
    3,058
    2,426
    I thought contrails were the result of the jet exhaust at high altitudes. Does this term also apply to the situation described above?
    G
  9. mtsu_av8er
    mtsu_av8er Well-Known Member
    Dec 14, 2002
    13,695
    191
    Contrail=condensation trail. The difference is the manner in which they are produced.
    When they form on the wing as a result of pressure differentials, they're called aerodynamic contrails.
  10. cargopusher
    cargopusher New Member
    Feb 8, 2004
    156
    0
    Is this the same as 'putting on the sweater"?
Share This Page
