Twin-engine planes can land safely on one propeller
Discussion in 'General Topics' started by bimmerphile, Mar 18, 2017.
  1. bimmerphile
    bimmerphile Open-Air Member
    Aug 21, 2014
    1,218
    1,780
    http://www.stuff.co.nz/world/austra...flight-forcing-emergency-landing-in-australia
    "Passengers on a Regional Express aircraft in Australia endured a nightmare flight after one of its propellers sheared off mid-flight, forcing it to make an emergency landing at Sydney Airport.
    The Saab 340, carrying 16 passengers and three crew, was about 10 nautical miles away from Sydney when its right-hand propeller flew off, forcing the two pilots to declare a PAN, which is one step down from a full-scale Mayday.
    Emergency services readied for the plane's arrival at the airport, but it landed safely shortly after midday on Friday.
    The plane's distraught passengers were taken to the terminal at Sydney Airport after the plane landed and offered counselling. The plane has been towed to Regional Express's hangar near the domestic terminal at Sydney Airport.
    Given the proximity of the turboprop aircraft over built-up areas near Sydney when the mid-air incident occurred, aviation sources said it was fortunate that the propeller did not injure people on the ground.
    The plane was likely to have been above Camden in south-west Sydney when the propeller sheared off.
    Early inspections of the plane suggest that the propeller has broken away from the shaft in the engine.
    Residents in south western parts of Sydney have been told to inform police if they discover the propeller, which will form a key part of an investigation into the incident.
    A spokeswoman for Regional Express said the airline was still investigating what caused the propeller to dislodge on Flight ZL768.
    "We are still investigating what happened and what was the cause," she said.
    A spokesman for the Civil Aviation Safety Authority confirmed that the plane's right-hand propeller "came dislodged" about 10 nautical miles from Sydney Airport, and the plane declared a PAN emergency before it proceeded on to land safely.
    Twin-engine planes can land safely on one propeller.
    The Australian Transport Safety Authority is investigating the incident."
    guess declaring an emergency is just too much paperwork in 'stralya
    Boris Badenov and Beefy McGee like this.
  2. etflies
    etflies Keeping calm, Chiving on.
    Apr 4, 2008
    994
    910
    I'm not surprised that it was a Saab, but I'm also equally not surprised that it handled/was handled like a boss.
    I still don't think I've ever trusted an airplane so completely to get me home, even if it was the creator of it's own issues.
    Sent from my SM-G930V using Tapatalk
  3. WS
    WS Well-Known Member
    Nov 27, 2014
    128
    58
    Losing an ENGINE would be an emergency, they just lost the PROPELLER... TOTALLY different LOL That happens all the time, NBD
    Beefy McGee likes this.
  4. Cory Trevor
    Cory Trevor Well-Known Member
    Apr 8, 2012
    107
    74
    Don't even need to worry about feathering it!
    ComplexHiAv8r, Yakob and WS like this.
  5. WS
    Nov 27, 2014
    128
    58
    You might be onto something there. Could be a new version of Autofeather, just jettison the prop. Even less drag & reduces the aircraft weight at the same time!
    Fixtur, DubyaDawg, Apophis and 3 others like this.
  6. Jordan93
    Jordan93 Well-Known Member
    Oct 27, 2015
    336
    376
  7. mastermags
    mastermags Well-Known Member *giggity*
    Apr 21, 2003
    2,883
    1,881
    Didnt work out too well for ASA.
    Autothrust Blue likes this.
  8. SurferLucas
    SurferLucas Southern Gentleman
    Jun 5, 2008
    4,739
    4,279
    Both times...I still cringe when I read about 529
  9. Cptnchia
    Cptnchia Well-Known Member
    May 16, 2007
    7,407
    8,148
    First time it was the torque transfer tube.
    Autothrust Blue and SurferLucas like this.
  10. SurferLucas
    Jun 5, 2008
    4,739
    4,279
    TIL
  11. Seb
    Seb Active Member
    Feb 13, 2017
    7
    4
    Just another Saab story...
  12. gotWXdagain
    gotWXdagain Highly Visible Member
    Jan 17, 2009
    2,926
    2,317
    Jet pipe thrust anyone?
    Sent from my iPad using Tapatalk Pro
  13. Autothrust Blue
    Autothrust Blue "We cannot afford it."
    Aug 3, 2010
    16,709
    9,747
    Indeed, single point of failure, and surprisingly fail-deadly. Having two pumps does zero good if you have only one way to command a pitch change.
    But with respect to the unscheduled jettisoning of a blade, in the case of 529, Nine Minutes, Twenty Seconds is an amazing read. The Brasilia had a certification waiver and was not required to survive the loss of a blade, if memory serves; the forces involved are spectacular.
  14. Bandit_Driver
    Bandit_Driver Gold Member
    Oct 31, 2003
    6,462
    771
    Good thing the over speed protection worked or that CT7 would have grenaded.
    The Saab is built pretty solid.
    ctab5060X, ASpilot2be and Roger Roger like this.
  15. ASpilot2be
    ASpilot2be SF340 CA
    May 1, 2005
    14,598
    3,097
    The SAAB is like sour patch kids. It will do something sour, then it will be sweet and get you home.
    ctab5060X and etflies like this.
  16. mshunter
    mshunter Well-Known Member
    Dec 11, 2008
    13,664
    4,725
    Obligatory "The front fell off" post.
    bimmerphile and Autothrust Blue like this.
  17. bimmerphile
    Aug 21, 2014
    1,218
    1,780
    Thankfully, the prop fell into a different environment
    Sent from my SM-G900V using Tapatalk
    mshunter likes this.
  18. mshunter
    Dec 11, 2008
    13,664
    4,725
    Well, at least now they don't have to tow it there.
    bimmerphile likes this.
Share This Page
