  2. Dear Visitor, registration is absolutely FREE!
    You can also start your membership quickly by using the "Login with Facebook" for fast registration!
    Get access to our live chat, members-only jobs section and more, today!
Skydive Pilot ?
Discussion in 'General Topics' started by UDaviator, May 13, 2012.
  1. UDaviator Muy Importante
    Nov 17, 2011
    Message Count:
    68
    3
    To all you diver drivers....how do you keep track of logable time!? It's my obvious first year doing this and would like to know. Our 182s and 206 don't have hobbs time and tach time is unreliable isn't it?? Any info would help! Don't know an "average" time yet per load and we do statics (out at 3) and tandems (out at 8-10). Cheers!
  2. drunkenbeagle Gang Member
    Mar 18, 2009
    Message Count:
    5,058
    635
    1.2 * tach.
    Or, use a watch. I usually log engine start every takeoff (I tow gliders, not meat missiles, but same thing)
  3. 1wrangler Well-Known Member
    Jul 19, 2011
    Message Count:
    39
    8
    You could use a watch (as stated above) or timer, but honestly after a week or so of doing it your flights will always average .5 on a hobbs meter, unless you're going up 12 or 13K, which would add a tenth or maybe two.
  4. moxiepilot Well-Known Member
    Aug 24, 2004
    Message Count:
    6,190
    400
    Your watch, a piece of paper and a pencil are your friend....
  5. drunkenbeagle Gang Member
    Mar 18, 2009
    Message Count:
    5,058
    635
    It is actually more like 1.4 tach towing gliders - you end up idling a lot.
    Time it with a watch 2 or 3 days, that will give you a good idea what to multiply the tach by.
    Or as a wise man once said, "Fly what you want, log what you need..."
  6. Shiek Yiboudi Divides by zero
    Nov 12, 2011
    Message Count:
    67
    52
    I always just wrote the Tach down in the morning and did the math in the evening when we were done. Unless you're lucky enough to have a hobbs timer or something on board, that's gonna be the best way.
  7. Inverted25 Well-Known Member
    Dec 18, 2008
    Message Count:
    2,530
    100
    I average out the time it takes for pattern,3k 4k and mile high tow. Now I used that number everytime
  8. Redline165 Well-Known Member
    Feb 24, 2011
    Message Count:
    7
    0
    Some planes are easier then others, the big turbines are pretty consistent time wise (within a few minutes) the Cessna are a little more challenging but after you get a rhythm it gets easier to predict time based on fuel and number of people. The climb rate in a 182 between 3 and 4 jumpers is certainly noticeable when going all the way up in the summer. I just take the load sheets at the end of the day and do the math.
    Besides, if you just take the boss-man on the grounds word on it he will swear you were taking .9 per load :)
  9. Dan208B Well-Known Member
    Mar 8, 2008
    Message Count:
    400
    35
    I don't try to make it difficult in any way. I figure how long is the average flight, maybe add a bit on a hot day, and remember how many loads I did. If one was really long for some reason like waiting for traffic, then remember one that day was longer.
  10. towpilot2003 Well-Known Member
    Mar 24, 2012
    Message Count:
    50
    11
    I do it the same way I keep track of fuel.. A watch and a piece of paper.
  11. Autothrust Blue Aging Geek
    Aug 3, 2010
    Message Count:
    7,875
    1,435
    I was distracted by your avatar...what did you say?
    Shiek Yiboudi likes this.
  12. UDaviator Muy Importante
    Nov 17, 2011
    Message Count:
    68
    3
    hey thanks for all the info guys! much appreciated
  13. drunkenbeagle Gang Member
    Mar 18, 2009
    Message Count:
    5,058
    635
    What are those numbers if you don't mind sharing?
    From my tow log and watch, 1.3something X tach is really close, but I also have a 30 minute taxi for fuel to deal with most days. And I really don't care that much either - I think I already have enough tows to satisfy any insurance company.
  14. Inverted25 Well-Known Member
    Dec 18, 2008
    Message Count:
    2,530
    100
    I averaged it out over a month last year and on average from full power to 3,000 AGL and back down to the runway was 12 minutes. I can do it faster but we are under a Class Bravo shelf extension now so I will cut the power back a little bit on the climb out after reaching 1000 AGL so that we slow the climb down and I am able to get the gliders outside the shelf. Pattern tows can be done in less than 6 minutes. So when figuring out my times for the day I will take the patterns tows and count them two for one and then add them to the 3000 footers. Then I multiply that number by .2 for entry into logbook. We dont do many tows over 3000 anymore because of the Class Bravo above us now because it would require some manuevering to avoid controlled airspace.
  15. vheissu Well-Known Member
    Aug 10, 2006
    Message Count:
    704
    34
    I do the same as the others have stated. I use average time for a load (20 min), and multiply that by how many loads I fly. I add a little for the hot days or when we do special things
  16. drunkenbeagle Gang Member
    Mar 18, 2009
    Message Count:
    5,058
    635
    Thanks! Had the bright idea of just leaving my data-logging vario on for the day. Would just need to log taxi time then :)
  17. TwoTwoLeft o- - - - - - -l
    Nov 23, 2010
    Message Count:
    1,266
    566
    I believe it was, boobs boobs boobs. Boobs. Blonde. Boobs boobs. Booooobs. At least that's what I got out of it. Your mileage my vary....
  18. towpilot2003 Well-Known Member
    Mar 24, 2012
    Message Count:
    50
    11
    I'm curious what you mean by "logable" time? I know that flying jumpers, time at the bar, hitting on DZ chics, taking girls for an "otter ride" and then taking them flying, along with "safety meetings" in the parking lot can be confused as logable... you mean when the motors running for the intent of flight, right? ;-)
Share This Page
