Question for USN types....
Discussion in 'Military Pilots' started by MikeD, Jun 2, 2004.
  1. MikeD
    MikeD Administrator Staff Member
    Feb 26, 2003
    38,596
    14,518
    What's the difference between a Hull Technician (HT) and a Damage Controlman (DC)? They sound the same to me.
  2. Stone Cold
    Stone Cold Well-Known Member
    Oct 26, 2003
    5,541
    1,659
    A Hull Technician is basically a plumber, doing lots of welding, etc. A Damage Controlman works on all the DC gear,i.e., fire hoses, extinguishers, Quick Acting Water Tight Doors (QAWTD), etc. They are both usually in the same division (at least on a Small Boy) and both usually pretty good at overall Damage Control, but a HT does more than DC when it comes to "fixing things". [​IMG]
    I hope that's clearer than mud now. [​IMG]
  3. mtsu_av8er
    mtsu_av8er Well-Known Member
    Dec 14, 2002
    13,695
    191
    Does the Navy still have DC's? You know you're getting old when you have to answer questions like that.... [​IMG]
    I actually did firefighter training at the Treasure Island Naval Station. That's when you know you're getting old!!!!
  4. Grabo172
    Grabo172 Well-Known Member
    Feb 19, 2004
    1,580
    8
    Yep, still have DCs.
    they have no BTs left though..
    Like said above, the DCs mainly do all the Firefighting and dewatering/shoring upkeep and maintenance, along with being the at sea and in port fire party leaders/members.
    The HTs fix the toilets and clean up the CHT (sound it out [​IMG]) when it overflows. They also mainly do alot of welding and pipe fitting.
  5. MikeD
    Feb 26, 2003
    38,596
    14,518
    Question #2. Customs/courtesies/traditions
    1. When ships arrive into Pearl Harbor, is it standard for them to render honors to the USS Arizona? Is it true that the Arizona is still a commissioned US Navy vessel?
    2. I'm a little bit familiar with the "shellback" concept of those that have crossed the equator; any Shellbacks here? How do they know who has/hasn't gone through the "ceremony"? Also, isn't there a similiar "ceremony" for submariners that have cruised under the polar icecap, or something similiar?
  6. H46Bubba
    H46Bubba Well-Known Member
    Nov 14, 2002
    7,006
    688
    Every ship that enters or exits Pearl Harbor renders honors to the Arizona. I'm not particularly sure about it still being a commisioned ship. I never had the privillage tobecome a shellback. You get a big certificate and it goes into you service record.
  7. mtsu_av8er
    Dec 14, 2002
    13,695
    191
    From what I understand, the ceremony (which used to celebrate the tradition of Shellbacks) has turned into a big PC feel-good gathering.... [​IMG].
  8. JEP
    JEP What are you looking at? Staff Member
    Jun 11, 2003
    19,120
    1,610
    DP3 Perrone here
    JC-Air America Member and Proud Shellback.
    I crossed the equator back in Dec. '92 and it was a day to relax (for previous shellbacks) and humiliate the polywogs (those that have not crossed the equator). They used to use old pieces of firehoses to whip the pi$$ out of everyone. After the Tailhook scandal all of the physical violence was stopped.
    If is was humilating and embarrassing they made you do it. Some of the stuff we did:
    stand watch in our workspace and bang a dustpan with a broom and announce when a Sheelback entered the space.
    crawled around the ship with underwear over our head that had a sock tied to it. we had to lean over and grab the sock from the guy infront of us.
    they had a obstacle course of sorts on the flight deck and it was more humilation. blowing water out of the tie-down holders, climbing through slop and probably the worst was Baby Huey....They took the fatest sailor and you would have to take an olive out of his belly button. At the very end of the obstacle course you jumped into a huge tub of filthy water and when you came up, a shellback would ask you, "what are you. A shellback or a wog. If you answer a wog, it was back through the course again. If you answerd a shellback it was over. You basically stripped off your clothes and threw them overboard into the ocean. At the time I was on the carrier, there were no women so the naked sailors on the flight deck may have changed. If you were smart you had someone with some towels so you could get back to your berthing area with out flapping in the wind. I think it took a few days to get all the junk and stench off of you.
    If you are on a ship that is crossing the equator, they can actually look at your prior duty stations and know if you have crossed the equator. I believe it may even be in your service equator, You also recieve an id-sized card and certificate that shows you have crossed the line as well.
    Probably more than you wanted to know. I can bring my card to Network JC. Maybe we need a cermony of some sorts for Vegas. [​IMG]
    when we crossed the equator, our XO was a polywog. It was fun to see him go through the same mess.
  9. shooter13
    shooter13 New Member
    May 14, 2002
    1,945
    0
    I haven't crossed the equator. We were almost there and got turned around to go do other things.
    Subs have Blue Noses which is for crossing the arctic circle. Everything is still very much like shellback but the theme is cold.
  10. MikeD
    Feb 26, 2003
    38,596
    14,518
    Excellent info, gentlemen. As one of the JC-Air America staff members, I need to familiarize myself will the nuances of each service that our members are from.
    Good work. And carry on!
    [​IMG]
  11. MikeD
    Feb 26, 2003
    38,596
    14,518
    Why do groundcrew at Navy/Marine Corps Air Stations always have the "micky mouse ears" helmets donned whenever they're on the flightline...even if no engines are running? [​IMG]
  12. H46Bubba
    Nov 14, 2002
    7,006
    688
    You're require to wear a "cranial" as it's called, whenever you are out on the flight line during flight ops and whenever you climb onto an aircraft. They have saved peoples lives, when they've fallen off the top of an aircraft.
  13. chunk75
    chunk75 Well-Known Member
    Jul 2, 2001
    974
    0
    My plan for SERE school was to tell them I was a BT (buffer technician)....kinda forgot to put the ole' plan into action after meeting "oak" for the first time...
  14. draglink
    draglink Well-Known Member
    Apr 4, 2004
    36
    2
    cranials have saved my poor noggin a lot of times
  15. JEP
    Jun 11, 2003
    19,120
    1,610
    Here's one for you other Navy guys.....When I reported to the carrier I was given a GQ station and it ended up being Fire lockers and my job was working on the firehoses. I got my gear during one of the drills and went to put on the (one size fits all) helmet and youe guessed it, it did not fit. That was the end of that GQ station. They sent me back to the Data Center where I was working and that became my new hoem during GQ. IT could not get much easier than that.
  16. clrd4takeoff
    clrd4takeoff New Member
    Feb 7, 2004
    71
    0
    Amen to that!!!
  17. draglink
    Apr 4, 2004
    36
    2
    you must have a giant melon...lol
    they are adjustable, there are some small lock-nuts
    that you can turn and extend the ear cup holders
    kinda similar to some el-cheapo headsets
Share This Page
