Piston Twin Good for Training and Transport -- Suggestions?
Discussion in 'General Topics' started by WestIndian425, Sep 19, 2009.
  1. CK
    CK Well-Known Member
    Aug 10, 2003
    2,007
    522
    Re: Piston Twin Good for Training and Transport -- Suggestio
    It's actually a Rockwell Commander, not an Aero Commander.
    http://www.controller.com/listings/aircraft-for-sale/COMMANDER-700/1979-COMMANDER-700/1151437.htm
    Call Roger, tell him you'd like to checkout the plane.
    Oil changes alone will be around $1000 a year if you fly 300 hours. You can run a good, clean Navajo for between $8 or 10,000 a year if your are flying the plane often. These airplanes are old, complex, break often, are are not cheap to fix. His $2300 is either based on parts only (do they have their own MX department?) or they only do the bare minimum.
    It has the TIO-541, Lycomings bastard engine. But you are correct, it is not geared.
    Alex.
  2. minitour
    minitour New Member
    Oct 13, 2007
    6,926
    5
    One off yet again.
    -mini
  3. WestIndian425
    WestIndian425 Well-Known Member
    Jan 5, 2006
    1,917
    207
    That's the one I was thinking of as well! I'll give him a call, but driving to VA is a bit of a haul from north Jersey.
    I see! Thanks for the info. He did mention that the engines needed to be overhauled, which would run about $35,000 (GASP!).
  4. CK
    Aug 10, 2003
    2,007
    522
    Again, a good overhaul will cost around $35,000 per engine on a big Lycoming.
    Alex.
  5. WestIndian425
    Jan 5, 2006
    1,917
    207
    Actually, I understood it to be that...so a Navajo, while a good aircraft, is quite expensive to maintain!
  6. dasleben
    dasleben That's just, like, your opinion, man
    May 1, 2006
    9,232
    5,426
    Any of these big twins are going to be. The TSIO-520s in the 414 are just as expensive.
  7. WestIndian425
    Jan 5, 2006
    1,917
    207
    I see...getting the most value for the money is harder than I thought.:insane:
  8. t-cart
    t-cart Active Member
    Aug 29, 2006
    2,291
    4
    I've got a great Apache for sale.
  9. jhugz
    jhugz The Juarez Express
    May 1, 2007
    5,946
    440
    Dude...I love that airplane. You just die single engine, the second engine is just for novelty. I wish I had the money to buy it off of you and then STC it for MoGas.
  10. t-cart
    Aug 29, 2006
    2,291
    4
    Well, you just come up with the money. It already has the STC. IFR too.
  11. jhugz
    May 1, 2007
    5,946
    440
    dahhhum...To bad I only make 10k/yr right now. You take a check? :)
  12. t-cart
    Aug 29, 2006
    2,291
    4
    :rotfl::rotfl::rotfl:
  13. WestIndian425
    Jan 5, 2006
    1,917
    207
    Okay, quick update:
    Today we went to check out a Cessna 340A (with the RAM package). This aircraft was pretty well-maintained (had all the logs too, and just completed an annual, though the engines are about 200 hours away from overhaul).
    Now for the experts among you, I'd like to know what are the pertinent questions to ask when shopping for an airplane. I can ask about equipment and maintenance and how the owners used the plane, but I'm sure I should be asking a lot more. What say you?
    Thanks! :)
Share This Page
