Multi-Engine Rental
Discussion in 'Flight Academies and Fixed Base Operators (FBO)' started by AirVenture, Apr 16, 2007.
  1. AirVenture
    AirVenture Well-Known Member
    Sep 27, 2006
    308
    0
    Hey everybody,
    I was wondering what the process is like for renting one of Skymate's Seminoles. I'll be spending three months at a job in the Dallas area and would like to keep my currency up and maybe build some multi time (15-20 hours). I see that they require 5 PIC in type for rental. I currently only have 2 hours, so I'll need to go up with instructor for a few hours, which is fine with me. It'll be a good way to get use to the area and comfortable again in the twin. Are the aircraft in good condition? What is their availability like? Are they available for overnight trips?
    Thanks,
    -Brett
  2. SmitteyB
    SmitteyB Well-Known Member
    Nov 15, 2004
    2,345
    39
    Airventure-
    The Seminoles are in good shape, later model, run perfectly. To be able to rent is a simple checkout and the required 5 hours of PIC. You can schedule the airplanes for overnight trips and there's usually one open most of the time. Look forward to seeing you down there...doh....here. Down here.
    And that is if you meet these requirements:
    Airman Cerification : AMEL, Private, Commercial or ATP
    Pilot Time : 250, of which 50 must be in complex aircraft
    PIC Time In Multi Engine Airplane: 25, or 5 hours PIC in Make and Model or completion of approved Skymates course of 10 hours.
  3. AirVenture
    Sep 27, 2006
    308
    0
    Hey sounds terrific. I'm a 410TT/20ME CFII and looks like I meet all of those requirements. I can't wait to get some fun Texas flying in! :)
    -Brett
  4. Goonie
    Goonie Never say die
    Nov 3, 2004
    4,266
    1,013
    Texas is flat.
    Its the largest landing strip in the world tho....
  5. CFIscare
    CFIscare Well-Known Member
    Jul 10, 2006
    1,476
    1,687
    Makes it easy to know when you need to pull up...
  6. CoffeeIcePapers
    CoffeeIcePapers Well-Hung Member
    Jan 21, 2007
    8,426
    2,061
    I am looking to split some multi-time. PM me when you get here.
  7. kellwolf
    kellwolf Piece of Trash
    Jun 17, 2003
    21,929
    952
    Ha! That's the first thing I said when I went up with Travis the first time. "Damn, well if I have an engine failure, I'm golden around here." Only difference b/w TX and FL is FL has more lakes and swamps to land in. :)
  8. Keebler
    Keebler New Member
    Oct 5, 2006
    154
    0
    You guys obviously haven't flown the canyon from Amarillo to Childress, though I suppose it's flat on top and at the bottom. Just let ATC know as there is no coverage down there.
  9. AirVenture
    Sep 27, 2006
    308
    0
    Sounds good, I'll let you know when I get settled in down there.
    I'm pretty use to flat up here in the midwest. However, it'll be nice to see something other than corn fields! While I'm down there I'd like to hit up a few states I've never been to (NM, LA, MS, AL, AR) and maybe fly back home once or twice.
    -Brett
  10. kellwolf
    Jun 17, 2003
    21,929
    952
    Flying into New Orleans is a good time. You're not missing much in MS. Asky WAFlyBoy about his adventure to AL in a Twin Commanche. :)
  11. jbpilot
    jbpilot Well-Known Member
    Aug 13, 2002
    31
    0
    I see that the Private Multi course that Skymates offers is only 4.5 hours of flight time. Does this qualify one to rent after completing the course, or do you still have to fly an additional 5.5 hours with an instructor afterward?
Share This Page
