More efficient: prop or jet?
Discussion in 'General Topics' started by caliginousface, Dec 5, 2007.
  1. caliginousface
    caliginousface Frank N. Beans
    Jul 16, 2005
    2,545
    61
    Hey all,
    Had a friend ask me, a plane a prop and jet of similar size, which is more efficient. Would like to hear more than just opinion if that's not too much to ask. Thanks!
  2. jynxyjoe
    jynxyjoe The Kickin' Chicken!
    Oct 31, 2007
    5,328
    3,136
    depends. long haul its more efficient for a jet, short haul its t-prop time.
    watch the new dash 8 -400's blow the doors off 50-70 seaters on short hauls
  3. caliginousface
    Jul 16, 2005
    2,545
    61
    What qualifies as short and long haul?
  4. USMC-SSGT
    USMC-SSGT Well-Known Member
    May 14, 2006
    1,824
    61
    typically around 500 miles or less
  5. Mr.Maximus
    Mr.Maximus New Member
    Feb 13, 2007
    286
    0
    Depends entirely on the mission. Type of flying I do - coast to coast & international - there is only one choice, and it has to cruise above .80M.
  6. caliginousface
    Jul 16, 2005
    2,545
    61
    Thanks for the answers btw, but he wants more that I can't give him (I'm a bad lover?).
    So...Why is a prop more efficient for short hauls. Why can they fly faster arrivals and/or approaches?
  7. E6BAV8R
    E6BAV8R Well-Known Member
    Nov 14, 2006
    795
    1
    The ole' shiny jets are much slicker through the air and therefore make it much harder for them to slow down so they generally have to start slowing down miles before a t-prop would.
    T-props have the huge props sticking out there that create massive amounts of drag and weight and it makes the airplane much easier to slow down if desired, as well as having the ability to move the prop angles to also help you in slowing down.
    In lamens terms ;)
  8. Cessnaflyer
    Cessnaflyer Wooooooooooooooooooooooooooooooo
    Dec 9, 2006
    8,052
    2,320
    Enter the Unducted Prop Fan.
    [FONT=ARIAL, Helvetica, Geneva][FONT=ARIAL, Helvetica, Geneva][FONT=ARIAL, Helvetica, Geneva]http://www.airliners.net/open.file/0001821/L/[/FONT][/FONT][/FONT]
    I really wish this would come to fruition.
  9. Dugie8
    Dugie8 Well-Known Member
    Mar 11, 2006
    3,986
    1,694
    Depends on your definition of "efficient". The PC12 can carry more gas than most people have space in their bladder, that can be called efficient. A DC8 can carry about 95,000#s about 4500 miles on 150,000 pounds of fuel, that can be called efficient.
    Time and fuel used aren't always the best benchmarks, but they are probably the most common.
  10. Derg
    Derg Naval Intelligence, MCRN Staff Member
    Dec 31, 1969
    31,895
    42,167
    Depends on how far you'd like to fly!
    Jets whizz a lot of gas below the tropopause and you don't enjoy the economics of a jet until you're able to get up high and cruise for a long time.
    Turboprops are very efficient in the teens and low 20's.
  11. MusketeerMan
    MusketeerMan Well-Known Member
    Jun 10, 2006
    2,763
    164
    Hmmmmm.....well, I can go from Sacramento to San Diego in my Beech for about $175 AND stop on a dime. Can you?? :rolleyes:
    Oh yeah, it'll also take me about 4 1/2 hours.
  12. Realms09
    Realms09 Well-Known Member
    Aug 14, 2002
    429
    0
    Different powerplants will be optimum for different speed (Mach) regimes.
    In order of increasing Mach,
    Turboprop -> Turbofan -> Turbojet -> Ramjet -> Scramjet -> Rocket
    Over short routes you are unlikely to average a high speed for very long, so there is no sense in carrying a high-speed powerplant. Even if each powerplant is operated in its optimum speed range, the turboprop will be the most fuel efficient. From an efficiency standpoint it is always better to accelerate a large mass of air a little bit than a small mass of air a whole lot. It would use less fuel to fly a turboprop transcon than it would an equivalent sized jet, but it would just take too damn long.
  13. Sidious
    Sidious Well-Known Member
    Oct 12, 2006
    878
    65
    That just looks wicked! Ive never even heard of this.
  14. B767Driver
    B767Driver New Member
    Sep 27, 2003
    2,016
    10
    Just to add on...the propulsive efficiency of turborpops and jets have much to do with the speed at which they fly.
    A turboprop will reach about 80% efficiency at around 280kts, then drops off sharply.
    A jet's propulsive efficiency actually increases with speed. A jet would reach 100% propulsive efficiency if its inlet air equalled its exhaust velocity. Although efficient, you still have to throw a lot of fuel around to get the thrust levels to reach those speeds. Probably not a good idea on a 300 mile leg.
    So, the answer to your friend's question...how far do you want to fly?
  15. flyover
    flyover New Member
    Mar 9, 2004
    3,379
    0
    On a transport type I'm guessing this would happen at some point after the wings separated from the fuselage? (Don't know much about arrowdynamics.)
  16. darrenf
    darrenf resident denizen
    Feb 11, 2002
    12,117
    1,815
    I remember seeing these things in Popular Science in the early to mid 80's. I guess they haven't worked out so well, or the manufacturers are afraid of the public opinion regarding props.
  17. PeanuckleCRJ
    PeanuckleCRJ Poodle Wrangler
    Dec 25, 2003
    2,814
    2,758
    Apparently the UDF made tremendous noise on the inside and outside as well as a lot of cabin vibration.
  18. taseal
    taseal Well-Known Member
    Nov 27, 2006
    1,981
    8
    yeah I made a project on this. it was WAY too loud, vibrations were nuts, and wasn't as efficient as they thought ti would be.
  19. frog_flyer
    frog_flyer FredFlyer
    Jan 6, 2006
    4,958
    200
    I couldn't tell.
  20. caliginousface
    Jul 16, 2005
    2,545
    61
    Thanks for the responses!
Share This Page
