  2. Dear Visitor, registration is absolutely FREE!
    You can also start your membership quickly by using the "Login with Facebook" for fast registration!
    Get access to our live chat, members-only jobs section and more, today!
METAR Question
Discussion in 'General Topics' started by Shiftace, Jun 11, 2012.
  1. Shiftace Low Time Private Pilot
    Feb 7, 2008
    Message Count:
    1,375
    386
    KFAR 111753Z 28029G38KT 10SM OVC033 16/05 A2980 RMK AO2 PK WND 28038/1749 SLP091 T01560050 10189 20139 53036
    I am trying to "decipher" the METAR past the PK mark. I understand that wind was 38 knots @ 280 at 1749 Z. What is after that?
  2. mjmuel0 Well-Known Member
    Aug 6, 2007
    Message Count:
    252
    22
    Sea level pressure, then full temp. Not sure last few sets of numbers
  3. ocdflyboy Well-Known Member
    Nov 1, 2008
    Message Count:
    801
    102
    SLP=Sea Level Pressure
    T01560050 is a more accurate Temp and Dew point 16/05= 15.6/5.0
    Annnd...
    T00640036 10066 21012 58033 TSNO $
    T00640036=HOURLY TEMPERATURE AND DEW POINT
    reported to nearest tenth of oC; sn: 1 if temperature or dew point below 0oC and 0 if temperature/dew point 0oC or higher.
    10066= 6-HOUR MAXIMUM TEMPERATURE,maximum temperature for past 6 hours reported to nearest tenth of degree Celsius
    21012= 6-HOUR MINIMUM TEMPERATURE, minimum temperature for past 6 hours reported to nearest tenth of degree Celsius
    58033=PRESSURE TENDENCY, the character (a) and amount of change in pressure (ppp) in tenths of hPa for the past 3 hours.
    $= Maintenance is needed on the system
    http://atmo.tamu.edu/class/metar/quick-metar.html
    I'm bored at work.
    beasly likes this.
  4. middies10 Well-Known Member
    Jan 14, 2010
    Message Count:
    293
    15
    SLP091 means the Sea Level Pressure is 1009.1mb. T01560050 means Temperature is 15.6 and the dewpoint is 5.0. Its just a more accurate reading. From then on, I can't help you.
  5. msmspilot Well-Known Member
    Feb 26, 2008
    Message Count:
    1,299
    43
  6. Shiftace Low Time Private Pilot
    Feb 7, 2008
    Message Count:
    1,375
    386
    Cool! Am bored at work too. The wind is howling outside, so I jumped on the interwebs to see what the METAR said.
    Thanks for the link and response!
  7. Blackhawk Well-Known Member
    Dec 10, 2006
    Message Count:
    2,745
    134
    Temperature/dewpoint does not matter for us pilots but for forecast models the 10th of a degree can make a big difference. SLP used for surface analysis.
  8. Rocketman99 Well-Known Member
    Jul 7, 2005
    Message Count:
    2,220
    159
    You're kidding right?
  9. Blackhawk Well-Known Member
    Dec 10, 2006
    Message Count:
    2,745
    134
    Read my entire post- when was the last time you read a performance chart that had 10ths of degrees? Though in fairness to you I may not have been clear.
  10. mojo6911 Well-Known Member
    Jan 21, 2007
    Message Count:
    6,565
    317
    He probably thought you meant T/D in general, and not the specific reading at the end of the METAR.
  11. Micah New Member
    May 14, 2012
    Message Count:
    7
    0
    AC-00-45f
    any question you will ever have regarding weather services is answered there
  12. Rocketman99 Well-Known Member
    Jul 7, 2005
    Message Count:
    2,220
    159
    It was the forecast models part that threw the sentence off. It reads like: pilots dont care about the t/d spread but forecasters are immensely concerned with tenths of degrees. No worries. Why I asked, wasn't meant to sound snippy.
  13. AA34 Well-Known Member
    Oct 21, 2005
    Message Count:
    122
    9
Share This Page
