Maximum altimeter error
Discussion in 'CFI Corner' started by SHayes, Feb 25, 2010.
  1. SHayes
    SHayes New Member
    Dec 25, 2009
    58
    0
    I though it used to say in the FARs the maximum altimeter error? Is there anywhere regulatory that says what it has to be? (+/- 75 feet)
  2. N18040
    N18040 Well-Known Member
    Apr 16, 2009
    302
    3
    Not sure on the reference, but I believe the 75 ft number is just for IFR.
  3. N18040
    Apr 16, 2009
    302
    3
    AIM 7-2-3 discusses it. I guess I was wrong about it only applying to IFR.
  4. PFGiardino
    PFGiardino Well-Known Member
    Jul 5, 2007
    595
    26
    And hence there is no "maximum allowable" when it comes to altimeter error... it's just a suggestion. However, I wouldn't be surprised to get violated in the name of careless & reckless if the situation warranted.
  5. CoffeeIcePapers
    CoffeeIcePapers Well-Hung Member
    Jan 21, 2007
    8,426
    2,061
    Its in Part 43 App. E
  6. SHayes
    SHayes New Member
    Dec 25, 2009
    58
    0
    I don't see it in Part 43, App, E. I see Table II (Test tolerances) but an average pilot about to set off on an instrument flight would not know that (or care - it is for AMTs).
    Anywhere else that makes it regulatory?
  7. SHayes
    SHayes New Member
    Dec 25, 2009
    58
    0
    That may be the only answer...the AIM. I have seen people try to say it was regulatory and some people say it wasn't. You are right though, "careless and reckless" would get you for sure.
  8. SIUav8er
    SIUav8er Narcosis
    May 31, 2005
    2,819
    11
    if you dont run into something on an approach first...
  9. CoffeeIcePapers
    Jan 21, 2007
    8,426
    2,061
    Part 43 requires the inspection, which requires that the altimeter be +-75 feet. We check before we fly to make sure it meets those tolerances.
  10. N18040
    Apr 16, 2009
    302
    3
    Your reference in the AIM is referring to Scale error. The only place that appendix E mentions 75 feet is not in reference to scale error, but in reference to the hysteresis test. I don't see how this tolerance could be applied to an altimeter sitting dormant on the ramp.
  11. SHayes
    SHayes New Member
    Dec 25, 2009
    58
    0
    I agree with you. I don't think anywhere is regulatory, that's why I asked.
Share This Page
