Malaysia Airlines 777 missing
Discussion in 'General Topics' started by ComplexHiAv8r, Mar 7, 2014.
  1. Pilot Fighter
    Pilot Fighter Well-Known Member
    May 14, 2013
    2,007
    1,501
    ...other than providing everything the French asked for.
  2. Roger Roger
    Roger Roger Navajo Whisperer
    Sep 4, 2009
    6,834
    7,860
    If nothing else, it will escape through the windows. I'm pretty sure every one of those has a built in pinhole leak.
  3. RDoug
    RDoug Well-Known Member
    Apr 6, 2011
    1,736
    1,213
    Unfortunately, I'm old enough. We were instructed to use that phraseology in cases where an aircraft's transponder was overwhelming our secondary. When that happened you'd get a secondary "ring" that would encompass the entire main bang at a distance equal to the actual target. Never actually saw it, nor had to use the phraseology, though.
    inigo88 likes this.
  4. inigo88
    inigo88 Composite-lover
    Jul 19, 2008
    1,921
    909
    Are we talking ARTS-III stuff? Or older? :)
    [​IMG]
  5. brent p h
    brent p h Well-Known Member
    Dec 24, 2007
    2,079
    73
    Paul Weeks who has disappeared with the Malaysia Flight is a Mechanical Engineer... he gave his wife a wedding ring & watch before boarding as if he knew something was wrong....
  6. brent p h
    Dec 24, 2007
    2,079
    73
    On searching Google, I found another Paul Weeks who is a Mechanical Engineer and guess what, works for Boeing....
    He specifically works on guess what plane?? Yep, Boeing 777 like the one that disappeared.
  7. SeanD
    SeanD Well-Known Member
    Jan 19, 2006
    11,233
    3,984
    Yeah, I read about that and though that was bizarre but some folks are pretty superstitious when they fly. My wife texts out a will to her mom every time she flies.
    dvtpilot and So ILL like this.
  8. Pilot Fighter
    May 14, 2013
    2,007
    1,501
    [I hate posts that make me do some math. Let's see, Archimedes principle will help with buoyancy. Now, volume of air compressed at half an atmosphere of depth.]
  9. SteveC
    SteveC Really? Staff Member
    May 14, 2003
    17,430
    2,261
    I think that we would need to do some calculations to see if the amount of initial buoyancy can offset the weight of the aircraft which is the only way that it would stay at or near the surface. I'm too lazy to dig, but you would need to know the total weight of the aircraft and the total volume, then compare the overall density (weight per unit volume) to the density of seawater. Higher density, it sinks. Lower density it floats.
    Once it starts sinking trouble happens in a hurry. Pressure doubles with every 35' or so of depth, so the volume of air would be squeezed into 1/2 it's original space every time the pressure doubles. Won't take long and the air in the vessel (if it doesn't leak out) will be in a small pocket at the roof of the pressure vessel.
    inigo88 and Pilot Fighter like this.
  10. SeanD
    Jan 19, 2006
    11,233
    3,984
    Ok, now that is bizarre if true.
  11. SteveC
    May 14, 2003
    17,430
    2,261
    Can we go back to that transponder question/statement you made earlier?
    A Life Aloft likes this.
  12. brent p h
    Dec 24, 2007
    2,079
    73
    His specific role:
    Product Review Engineer II - 777 Wing & Final Body Join Integration at Boeing.
  13. Pichettet1
    Pichettet1 Well-Known Member
    Jul 26, 2013
    177
    137
    Not the same Paul Weeks.
  14. brent p h
    Dec 24, 2007
    2,079
    73
    The plane that disappeared had it's wing clipped by another plane and had to be repaired....
  15. brent p h
    Dec 24, 2007
    2,079
    73
    One other thing... I read or heard on the news that the plane went through routine maintenance two weeks ago. I would like to see what they did and who they work for.
  16. A Life Aloft
    A Life Aloft Well-Known Member
    Sep 2, 2010
    8,802
    11,343
    And this means what exactly? So what? It's a different person with the same common name.
  17. brent p h
    Dec 24, 2007
    2,079
    73
    Another passenger on the plane was called Robert Lawton. I have found a Obituary for the death of a different Robert Lawton back in Feb 2013....One of his jobs, he worked as a joint mechanic on BOEING 777 planes....
  18. Pichettet1
    Jul 26, 2013
    177
    137
    Stop, just stop. At least look into what you're suggesting more than seeing a LinkedIn profile with the same name before posting this garbage. The Boeing employee's LinkedIn https://touch.www.linkedin.com/?se...//www.linkedin.com/pub/paul-weeks/33/6b8/b31
    He graduated in 2011, looks like he's 25. Not from NZ, lives in Washington. C'mon man.
  19. A Life Aloft
    Sep 2, 2010
    8,802
    11,343
    That happened two years ago and was rather minor. It was the tip of one wing. Have you seen the photos? It was repaired by Boeing.
  20. Pilot Fighter
    May 14, 2013
    2,007
    1,501
    Can't we apply Archimedes principle and ignore density. Damn I'm getting old. Did I forget or did I never know this stuff. Do they still make those big engineering handbooks that have every calculation you could think of?
    At .25 ATM, I don't think we are compressing much, but it grows quickly as you descend.
    I deleted my post to give it some more thought, probably too lazy to do the math.
Share This Page
