ISA Definition
Discussion in 'Technical Talk' started by majorityof1, Jan 30, 2008.
  1. majorityof1
    majorityof1 New Member
    Jun 18, 2007
    182
    0
    It seems as though this would be an easy google but I am coming up short...
    What is the difference between celsius and ISA celsius. Moreover, which one is commonly used in weather (ATIS, etc..). Why have two different ones?
    Thanks in advance.
  2. tgrayson
    tgrayson New Member
    Sep 14, 2006
    4,882
    6
    Can you quote the context?
    I would be inclined to say that "ISA Celsius" is merely quoting the International Standard Atmosphere (ISA) temperatures in Celsius; normally, they'd use Kelvin. Celsius = Kelvin - 273.15.
  3. majorityof1
    Jun 18, 2007
    182
    0
    Sure can. I am reviewing the dash limitations and the ambient temperature limit is the lower of +48.9 degrees celsius or ISA +35 degrees celsius. Besides being really hot which one is the Celsius that I know and love from ATIS reports?
  4. surreal1221
    surreal1221 Well-Known Member
    Jul 17, 2006
    18,952
    1,571
    What is ISA?
    And add 35 degrees to that.
    So, ISA + 35 = 15+35 = 50C.
    Hopefully that clears up any confusion.
    There is only ONE Celsius, and ONE Fahrenheit.
  5. Clocks
    Clocks Well-Known Member
    Mar 26, 2007
    2,756
    1
    I think this is referring to the fact that the standard temperature changes with altitude.
    At sea level ISA+35 = 15+35 = 50C. At 1000' MSL ISA+35 is 48C. At 2000' its 46C. At FL200 its -5C, etc.
    The ERJ has a similar limitation. ISA+35 is the max temperature for the aircraft. But max temperature for takeoff is 52C. How is that possible? Its because we can take off at -1000MSL, where ISA+35 is 52C.
  6. tgrayson
    tgrayson New Member
    Sep 14, 2006
    4,882
    6
    I agree with Clocks analysis.
  7. majorityof1
    Jun 18, 2007
    182
    0
    Well that makes some sense. What does ISA stand for?
  8. Clocks
    Mar 26, 2007
    2,756
    1
    http://en.wikipedia.org/wiki/International_Standard_Atmosphere
    The basic number to remember (as it relates to those temperature limitations) is standard temperature at sea level is 15 C, and it changes at a rate of -2C per thousand feet you go up in the troposphere (and +2C for every thousand feet you descend)
  9. Olympic
    Olympic Well-Known Member
    Dec 13, 2002
    135
    0
    1.98C just to be exact ... JAA guys understand.
  10. wzgrza
    wzgrza Well-Known Member
    Dec 23, 2007
    298
    1
    And im thinking of converting.. this is gonna be a pain in the ass :banghead::banghead:
  11. Olympic
    Dec 13, 2002
    135
    0
    I use 2 but for the exams they will have 1.98 and 2 .... damn JARS.
Share This Page
