  2. Dear Visitor, registration is absolutely FREE!
    You can also start your membership quickly by using the "Login with Facebook" for fast registration!
    Get access to our live chat, members-only jobs section and more, today!
  3. Watch Jeopardy tomorrow night and cheer on Mike Lewis! (Moderator)
Is DME required? SNA LDA 19R
Discussion in 'Technical Talk' started by Cessnaflyer, Jun 13, 2012.
  1. Cessnaflyer Concessions? I have nothing to concede!
    Dec 9, 2006
    Message Count:
    4,916
    448
    http://tiles.skyvector.com/sky/files/tpp/1206/pdf/00377LDA19R.PDF
    I was looking at this plate from another forum and thought it was interesting.
    There is no DME in the title, no DME required anywhere on the plate. Yet it says use DME to identify IAF/FAF TUSTI. It also has a timing table which would also mean you don't need necessarily need DME for the approach. The note makes it seem like DME is required to identify an important fix but does not require DME anywhere on the plate.
    What do you think?
  2. inigo88 Well-Known Member
    Jul 19, 2008
    Message Count:
    1,475
    414
    Can't TUTSI also be identified by passing thru the SLI R-080? I didn't see anything on that chart that would necessitate DME.
  3. rframe pǝʇɹǝʌuı
    Nov 24, 2010
    Message Count:
    2,525
    1,553
    I dont believe DME is required since every fix on the approach could be identified as an intersection off SLI. I believe that note is just there to clarify which navaid you should base DME on if that's what you are using to identify the steps.
    I think they put that note in when there are multiple navaids displayed on the approach that "could" give you DME and might cause confusion. In that plate, I'm betting SLI has DME too.
    Sort of like the ILS at COE, since you have the localizer signal on one channel but need a second to pull DME from the VOR... so the same type of note about DME source note is in the profile box on that plate http://155.178.201.160/d-tpp/1206/00527ILD5.PDF. The difference with COE of course is that DME is in fact required because there are no intersections to identify the steps. But I think the note is there just as an extra "hey pay attention" thing.
    That's just my best guess.
  4. ShortField Well-Known Member
    May 4, 2011
    Message Count:
    121
    16
    Looks like you can use the radials off Seal Beach, but I see what you're saying. That note makes it sound like you are supposed to ID the fix with DME on the LOC course.
  5. Cessnaflyer Concessions? I have nothing to concede!
    Dec 9, 2006
    Message Count:
    4,916
    448
    The thing that is confusing is the cross and use the LDA DME in the profile view.
    That seems to be the best explanation. I never noticed it before on other plates but it makes sense to avoid confusion on which DME to use.
  6. Blackhawk Well-Known Member
    Dec 10, 2006
    Message Count:
    2,745
    134
    Or ask SOCAL to fix Tusti.
  7. UAL747400 Well-Known Member
    Sep 30, 2002
    Message Count:
    4,115
    464
    Terrible note! I would miss it for sure if I had to set up for this approach quickly! I'm going with no, it's not required, even though it is or is it?... :bang::D
  8. ozziecat35 Well-Known Member
    May 28, 2006
    Message Count:
    1,974
    245
    That's what I was reading...the fact that each fix is annotated as a DME distance kind of infers DME required...but I agree SLI radials should provide you info needed as long as you are on the LOC.
  9. z987k Well-Known Member
    Feb 3, 2010
    Message Count:
    5,041
    985
    Anyone got the jepp plate handy? I bet it's considerably clearer.
  10. Itchy Well-Known Member
    Nov 12, 2007
    Message Count:
    2,281
    364
    If it were required, me thinks it would be in the title (name) of the approach.
    The dme lets you id the fix, and use the second ILS (receiver) the way it is supposed to be used, and not tying it up for radials.
    Ahhh... GPS rocks, does it not?
  11. Autothrust Blue Conveying multiple attitudes
    Aug 3, 2010
    Message Count:
    7,638
    1,304
    Eh, it doesn't really.
    As stated:
    I do as a matter of fact.
    There is a note on the plate, in the briefing strip: "Use IOJW DME when on LDA course." Each fix is also presented with the normal cross radial and D10.2 IOJW indication.
  12. jmc4 Well-Known Member
    Mar 18, 2011
    Message Count:
    27
    9
    First post! My guess, I'm going to say no, because it's not in the title. :D Also, you can ID the fix with cross radials. Same deal with the MAP, you could use DME to be much more precise, or just go missed via your time from FAF. I guess that note was put in to help with possible confusion?
  13. Autothrust Blue Conveying multiple attitudes
    Aug 3, 2010
    Message Count:
    7,638
    1,304
    Since you could also receive DME information off the SLI VORTAC, that makes sense - that's why the note is there, so there is no ambiguity as to which DME source you should use while on the final approach course.
    By the way, required equipment can also be named in a note as well as in the procedure title: "DME or RADAR required."
Share This Page
