  2. Dear Visitor, registration is absolutely FREE!
    You can also start your membership quickly by using the "Login with Facebook" for fast registration!
    Get access to our live chat, members-only jobs section and more, today!
Hard line oil pressure replacements?
Discussion in 'The MX Hangar (A&P/AMT)' started by rframe, Nov 11, 2011.
  1. rframe pǝʇɹǝʌuı
    Nov 24, 2010
    Message Count:
    2,538
    1,574
    If replacing an old Cessna hard line oil pressure line with Stratoflex 193-2, with 311-2D fittings does this produce a direct replacement... or does any of the AN hardware need to change? In other words, are the 311-2D shaped to fit the same male flare fittings that the hard line did?
  2. rframe pǝʇɹǝʌuı
    Nov 24, 2010
    Message Count:
    2,538
    1,574
    BTW, same as Aeroquip 471-2D if that is more familiar.
  3. Roger, Roger Guest
    Should all be the same 37* flare fittings. Just, uh, make sure you do a good leak check on the ground before you go fly.
  4. rframe pǝʇɹǝʌuı
    Nov 24, 2010
    Message Count:
    2,538
    1,574
    Thanks Roger, that's what I was thinking but wasn't quite sure.
  5. rframe pǝʇɹǝʌuı
    Nov 24, 2010
    Message Count:
    2,538
    1,574
    Anybody have a trick for installing the #2 471 fitting? I know you can use a mandrel on the larger fittings but there is no mandrel available for the tiny #2... not sure how to get the inner threaded fitting inserted into the tubing, need something to push and turn on the inner fitting to thread it into the tubing.... seems like it should be easy but something isn't adding up.
  6. rframe pǝʇɹǝʌuı
    Nov 24, 2010
    Message Count:
    2,538
    1,574
    In case someone comes across this in a search: just buy a spare male fitting, screw it into the flare end of the 471 hose fitting and use that to push/thread the inner piece.... works just fine.
Share This Page
