flying a STAR
Discussion in 'Technical Talk' started by STS-41B, Feb 2, 2017.
  1. STS-41B
    STS-41B Well-Known Member
    Oct 16, 2009
    291
    58
    Not so much a technical questions as much as a technique.. didn't know where else to post it.
    When you're flying a STAR.. do you put in the bottom altitude and follow the VNAV snowflake to ensure you hit the altitude windows? Or do you put in each lower altitude and do it "piece meal" as you go?
    I fly the CRJ.. whenever I jumpseat (which is usually on a 737 or A320), they put in the bottom altitude.
    Most captains I fly with on the CRJ, do it "step by step", setting the lower altitude of the next window and making sure the "banana" is just ahead of that fix.. which is how I usually do it.
    I recently flew with a captain who put in the bottom altitude.. he showed me the technique, etc.. and it seems a lot better. I did it on my legs and had no issues whatsoever.. I know I won't be able to always do it because many captains will freak out and I won't have time or energy to explain what I'm doing (lol)
    Just curious what others (esp CRJ drivers) do
  2. Dugie8
    Dugie8 Well-Known Member
    Mar 11, 2006
    4,082
    1,818
    Bottom altitude.
    I guess it all depends on how smart your FMS and VNAV are. As long as the altitude constraint is "in the box" VNAV should respect the altitude at each waypoint.
    Speed on the other hand....
  3. n156499000
    n156499000 Titanius Anglesmith
    Apr 19, 2012
    211
    113
    Considering the "advisory" nature of the VNAV in thru CRJ, I go fix by fix and spin the altitude down as I pass each one. Depending on the AT/ABOVE/BELOW nature I just manage the banana to be able to keep a constant descent as much as possible. As long as you don't bust any altitudes/speeds it shouldn't matter because it is, as you say, all a matter of technique.
  4. msmspilot
    msmspilot Well-Known Member
    Feb 26, 2008
    1,592
    244
    We put the next "hard" altitude. Usually that's the bottom, but some have an intermediate hard altitude, and I'll spin it once that one is pretty assured.
  5. Beefy McGee
    Beefy McGee Well-Known Member
    Apr 15, 2011
    652
    733
    My company flies the CRJ 200, 700, and 900, with a mix of NextGen and "legacy" models. Sometimes I set the bottom altitude and follow the snowflake via manual adjustments to the autopilot, sometimes I set the first hard altitude and VNAV it, and sometimes I dive and drive for each fix, depending on my mood. It breaks up the routine for me and also lets me practice the different methods. Just remember to adjust the VPA if there is a special one for the STAR besides the standard 3 degrees. And pay attention in case it's an imperfectly designed STAR, as sometimes you can follow a snowflake on the proper VPA and still miss an altitude or gate.
  6. bike21
    bike21 Somewhat Known Member
    Nov 27, 2004
    4,181
    1,633
    Without fancy VNAV in the CRJ I wouldn't always put the bottom altitude in. It depended on the day/winds/arrival so I don't think there is a 'wrong' technique as you have to more actively manage than sitting back watching the magic happen in a VNAV capable aircraft.
  7. Jordan93
    Jordan93 Well-Known Member
    Oct 27, 2015
    320
    371
    I put the first hard altitude in the ALT pre selector.
  8. KClark3
    KClark3 Well-Known Member
    Aug 16, 2014
    20
    10
    Not to change the subject but i've got a question to add on top of that. When flying a STAR and the controller says "resume normal speed", do you guys go with normal descent speed for your aircraft or the speed thats published on the STAR?
  9. CatchyScreenName
    CatchyScreenName Member
    Nov 17, 2016
    50
    14
    What's your POH and/or OpSpec say to do ?
  10. CatchyScreenName
    Nov 17, 2016
    50
    14
    STAR
    KClark3 likes this.
  11. adk
    adk Steals Hotel Toilet Paper
    Jan 20, 2009
    658
    448
    "Resume Normal Speed" compels you to comply with the restrictions of the star.
    "Delete Speed Restriction" means go whatever speed you'd like.
    KClark3 likes this.
  12. Dugie8
    Mar 11, 2006
    4,082
    1,818
    I believe that would be an incorrect instruction from ATC.
    If you were given a speed assignment contrary to the STAR but then the controller wanted you back on the published speeds, the instruction should be
    "Comply with speed restrictions"
    AIM 4-4-12
    AIM 5-5-9
    Acrofox, adk and KClark3 like this.
  13. KClark3
    Aug 16, 2014
    20
    10
    THAT was the phraseology i was looking for thank you! I've been trying to figure that one out
  14. adk
    Jan 20, 2009
    658
    448
    Looked it up in the 7110.65 .... you are correct. "Resume Normal Speed" is not supposed to be used when there is an underlying speed restriction (i.e. on a STAR).
    KClark3 likes this.
  15. CoffeeIcePapers
    CoffeeIcePapers Well-Hung Member
    Jan 21, 2007
    8,431
    2,066
    Proline 21: Dial down the bottom altitude, assuming you're given descend via, hit vnav and watch it go.
    Older avionics, I manually dial in hard altitudes in the FMS and manually descend, since there's no VNAV capture.
Share This Page
