  2. Dear Visitor, registration is absolutely FREE!
    You can also start your membership quickly by using the "Login with Facebook" for fast registration!
    Get access to our live chat, members-only jobs section and more, today!
F-16s intercept unauthorized small plane....
Discussion in 'General Topics' started by A300Capt, Feb 16, 2012.
  1. Cptnchia Well-Known Member
    May 16, 2007
    Message Count:
    3,038
    255
    Yeah, because the C-182 has such an impressive kill/loss ratio.
    Nah, but seriously, I get what you're saying. Nothing like bringing a crew served weapon to a slap fight.
  2. Hacker15e Member Of Extraordinary Magnitude
    Oct 3, 2006
    Message Count:
    6,069
    1,411
    Well, first off, it's because military fighters don't have "V-speeds". That's something you get in civilian aviation for standardization.
    More correctly, though, is because fighters don't have a "stall speed" per se -- it is measured by AOA. In fact, the F-15E and T-38, the jets that I have the most time in, don't have a published "stall speed" anywhere in the literature. Stall is measured by AOA as well as environmental factors (like knowing when the buffett you're feeling on the airframe has reached an intensity to the point where the aircraft is actually stalled).
    Why? Because the stall speeds change, depending on fuel and stores load. It's not a static number. Again, AOA is the only reliable method of actually determining when the airplane is stalled. Also, remember that for jets that are maneuvering, stall AOA can be reached at a wide range of airspeeds through the flight envelope (e.g., accelerated stalls) and that is something that can be used during tactical maneuvering.
    Even at that, the AOA number doesn't dictate how slow I can actually fly in a fighter. I have flown F-15Es and T-38s well below what would be those stall speeds -- at high AOA and in afterburner. The AOA says that the airplane is fully stalled, and yet I can fly airspeed/altitude/heading to Commercial PTS standards. Same thing as when you see the Blue Angles fly the F-18 at high AOA but very slow; the airspeed is well below where the airplane would stall if it were just relying on Mr Bernoulli for lift, but the airplane is still most definitely flying controlled.
    So, knowing those speeds doesn't really help anyone understand the issue.
    Stomp16 and rondebmar like this.
  3. Hacker15e Member Of Extraordinary Magnitude
    Oct 3, 2006
    Message Count:
    6,069
    1,411
    Yes, fighters -- like any other aircraft -- have a L/Dmax point on the lift/drag/power curve, below which it is distinctly not at an energy advantage. This is why most fighters have the FAA waiver to do 300 knots below 10,000 feet, because L/Dmax sits in the neighborhood of 250 for many of them.
  4. BEEF SUPREME Well-Known Member
    Dec 23, 2009
    Message Count:
    1,245
    298
    Try and catch me ridin dirtay!
  5. ///AMG Well-Known Member
    Nov 29, 2008
    Message Count:
    2,802
    260
    Great post from Hacker. To add to that, the Hornet actually has unlimited AoA as long as we aren't carrying a bunch of ait-to-ground stores or assymetric loading. It's quite easy to see 50-60 alpha in heavy maneuvering at slow speed if you overdo the pull a little bit. Still completely controllable. You can also go from 300+ kts to 48 in the HUD (basically 0 in the hornet) in a matter of seconds with a max performance pull. There is no stall, or any sort of indication of exceeding critical AoA or anything like that. You will be in a cloud of vapes coming off the LEX's and there is a lot of buffeting from the vertical stabs, but that is about the only way to know that you are now really no longer flying.
  6. mshunter Well-Known Member
    Dec 11, 2008
    Message Count:
    7,441
    454
    Why is it you military guys always get to rub this stuff is our faces! If I were king for a day, I'd make you take me for a ride. :cool:
  7. Hacker15e Member Of Extraordinary Magnitude
    Oct 3, 2006
    Message Count:
    6,069
    1,411
    If I were King, I'd take you. I actually love to take people on rides and share what a cool experience it is.
    My offer to take folks in the T-38 sims if they ever make it up my way is still open.
  8. ///AMG Well-Known Member
    Nov 29, 2008
    Message Count:
    2,802
    260
    I'd love to take folks as well, but among other things, there is not another seat. I've actually never even taken my wife flying, so I guess I better go rent a Cessna or something and take care of her first before I start taking other people :)
  9. MikeD Administrator
    Feb 26, 2003
    Message Count:
    29,065
    1,704
    Its the magic of thrust! :) The -38 is a great aircraft to see and teach how the AOA relationship works in terms of the wide stall regime.
  10. MikeD Administrator
    Feb 26, 2003
    Message Count:
    29,065
    1,704
    Correct. And more so for if that same Cessna/Piper/Lear/whatever is determined to be hostile and it's intentions unknown (or even known) and it's heading towards somewhere that it shouldn't be and won't deviate, OR is going towards it's known target......one has to be in a position to kill if need be.
    Back during the Payne Stewart incident, there was serious talk at high levels of what to do with the aircraft if it began to head towards a major metropolitan area. Serious talk of potentially knocking it down, and the legality of doing such an unprecedented move.
    Similar to my Accident Synopsis "Flight of the Unintentional UAV" that one can find in the Tech Topics section, only difference being that the aircraft in the 1971 story was flying with no one in it. Stewart's incident was the first with persons.....US citizens.....onboard where that decision was being considered.
  11. pete2800 Well-Known Member
    Jan 24, 2011
    Message Count:
    321
    139
    Where are you?
    :D
  12. JordanD Sizeable Member
    Nov 20, 2007
    Message Count:
    4,518
    972
    Yeah, that.
  13. Apophis Resident Iconoclast
    Jun 16, 2010
    Message Count:
    2,600
    586
    Yeah, well I'll trade a blimp ride for a pointy-nose jet ride. Any takers????
    Anybody?? :)
  14. Hacker15e Member Of Extraordinary Magnitude
    Oct 3, 2006
    Message Count:
    6,069
    1,411
    Vance AFB in Enid, OK. It's about 90 minutes from OKC, 2 hours from Tulsa, and 2 hours from Wichita.
  15. DiverDriver22 Member
    Nov 29, 2011
    Message Count:
    88
    5
    I'm in San Antonio!!!
  16. pntbllr233 Well-Known Member
    Dec 23, 2007
    Message Count:
    311
    5
    Or exactly 51NM from PWA. I fly up that way quite often just for the cross country time. I might have to take you up on that one day if you're still offering.
  17. Hacker15e Member Of Extraordinary Magnitude
    Oct 3, 2006
    Message Count:
    6,069
    1,411
    Yep. It takes a little prior planning, so give me some warning and I'll see what I can set up.
  18. MikeD Administrator
    Feb 26, 2003
    Message Count:
    29,065
    1,704
    Congratulations. :)
  19. Apophis Resident Iconoclast
    Jun 16, 2010
    Message Count:
    2,600
    586
    Damn, too bad I didn't know about the T-38 sim offer before I graduated OSU. Stillwater isn't very far from Vance at all. In fact, we got aircraft all the time doing training in the pattern from Vance.
    Anyways, my blimp offer still stands! :)
  20. BEEF SUPREME Well-Known Member
    Dec 23, 2009
    Message Count:
    1,245
    298
    http://415vva.homestead.com/Mil_Hist___Battle_of_Palmdale.pdf
    inigo88, ChasenSFO and Bernoulli Fan like this.
Share This Page
