Engine RPM's vs. manifold pressure
Discussion in 'Technical Talk' started by av8or91, Jun 16, 2008.
  1. av8or91
    av8or91 Well-Known Member
    Jan 8, 2008
    726
    14
    Ive always been taught to keep manifold pressure at or below what the rpm setting is. I was told by my last instructor that increasing manifold pressure past what your rpm setting is can put serious strain and wear on the engine. I believe he called "overboosting". This was in a non turbo aircraft so not sure if that s the correct term. IS this the general consensus and is the information correct?
  2. tgrayson
    tgrayson New Member
    Sep 14, 2006
    4,882
    6
    It's usually called "oversquare" and is an old wive's tale. You can find numerous oversquare settings in the POH of most airplanes with constant speed props.
    There are limits, though. Very low RPM with a very high manifold pressure can be stressful on the engine. On the Lycoming IO-360, the spread can be something like 5" on the high side, something like 2000 RPM and 25" MP. The only Continental I looked at was lower, but in general, anything in your POH should be fine.
    Beware of these bizarre rules that flight instructors give you.
  3. Hacker15e
    Hacker15e The Intersection of Opportunity and Preparation
    Oct 3, 2006
    11,315
    12,276
    "Oversquare" is a rule-of-thumb, not an absolute.
    In fact, if you fly a Beech Baron (or, I expect, a Bonanza as well) many of the tech order power settings violate the oversquare ROT. So much so that my CFI explained it to me as "Beech backwards"!
  4. Berkut
    Berkut Well-Known Member
    Oct 12, 2000
    1,093
    2
    Sometimes I wish they would calibrate manifold pressure gauges in PSI or millibars instead of inHg. That would make it less tempting to find some relationship there just because the numbers are close.
  5. ctab5060X
    ctab5060X Well-Known Member
    May 25, 2007
    4,998
    1,544
    No kidding!
    Here is a picture a friend of mine took several years back. We had just departed (just under gross that afternoon if I remember correctly). Take a look at the MP vs RPM. Keep in mind though that these are P&W R-985s though... (hint...MP is 32", RPM is 2100). If I remember correctly, the bottom arc for the green on MP is 17" (top is 32.5) and the top of the green on RPM is 2100 (bottom is 1700).
    [​IMG]
  6. av8or91
    Jan 8, 2008
    726
    14
    So just as an example, running 27 inches of manifold pressure at 2500 RPM is ok?
  7. Minuteman
    Minuteman “Dongola”
    May 16, 2003
    6,823
    2,468
    Only if 915 millibar at 2,500 RPM is OK. They're just numbers. Check Section 5 of your POH for the "Cruise Performance" tables. At higher altitudes you might have some power settings that have the MP (in inHg) be higher than the RPM (in hundreds).
  8. tgrayson
    tgrayson New Member
    Sep 14, 2006
    4,882
    6
    You can't make a statement that applies to all airplanes. According to the Lycoming engine manual for the IO-360, you can take the RPM all the way down to 1800 for a MP of 25". This may not be true in all airplanes. If you don't have the engine guide for the airplane, you simply don't know. Used published settings in the POH as a guide; I'm sure there's a lot of safety built in.
    Here are some good articles that will touch on these issues:
    http://www.avweb.com/news/pelican/182544-1.html
  9. WalterSobchak
    WalterSobchak Well-Known Member
    Oct 5, 2007
    1,438
    43
    Turbocharged airplanes are almost always over square. 40'' 2700 rpm's on a mooney 231. Over square is bs do what the book says its in there for a reason.
  10. BajtheJino
    BajtheJino I'm looking at you.
    Feb 12, 2007
    3,906
    495
    N210Q has some sweet tata's.
  11. aloft
    aloft New Member
    Sep 5, 2001
    8,933
    4
    It's impossible to overboost a nonturbocharged engine. In fact, the highest manifold pressure reading you'll probably ever see on it is when it's shut down!
  12. Hacker15e
    Oct 3, 2006
    11,315
    12,276
    The idea is to limit strain on the engine for the machine's long-term health.
  13. USMCmech
    USMCmech Well-Known Member
    May 3, 2004
    4,852
    1,824
    You don't realize it, but a C-172 is ALWAYS "oversquare" when at full throttle. 2500 RPM, and about 29" MAP. Only there is no MAP guage, so nobody notices.
    There are four completely wrong "rules" out there that keep getting passed down from CFI to CFI. PLEASE help put a stop to this.
    1, Never run your engine oversquare, doing so will overstrees the prop and crank.
    Not true, operate with power setting as found in the POH. The concidence that the most efficient prop RPM and the airpressure at cruising altitudes are nearly the same is just that, a concidence.
    2, Pull the power back to 25" inches durring climb.
    Closeing the throttle slightly also closes the power enrichment valve. Therby leaning the mixture dramaticly durring a peroid that is creatign the most heat already. Full throttle all the way to cruise altitude actually keeps the engine cooler.
    3, If you run your engine too lean, it will burn up.
    The most dangerous mixture is 50 deg ROP, that is where detonation is the most likely. You want to either be 100 ROP, or 50 LOP. Eitherway results in the same amount of heat and strain on the engine.
    4, If you pull the popwer back too fast on a descent, your enigne will shatter due to "shock cooling"
    It's made of aluminum, not glass. The only case of damage I have ever heard of that might have been realted to overcooling, was the result of gross abuse, well beyond what any sane pilot would do. I used to fly skydivers in a 182 where we climbed to altitude with the CHTS climbing over 450, then gave it a mear 2 minutes to cool off, followed by a Vne descent. It ran fine well past TBO, if that didn't create "shock cooling" nothing will. As long as you make a modest power reduction for about a 500FPM descent, you'll be fine.
    To all CFIs, read and re read Deakins articles on Avweb.
  14. av8or91
    Jan 8, 2008
    726
    14
    Thanks for all the responses I checked out the performance section for the piper seminole and found some manifold pressure settings that are higher than the RPM setting. Thanks USMCmech for nullifying some CFI myths.
  15. trafficinsight
    trafficinsight Well-Known Member
    May 8, 2007
    4,269
    1,982
    Man I'm so glad I'm not the only one that thinks shock cooling is a myth.
    Also, idle mixture is set rich for a reason.
  16. tgrayson
    tgrayson New Member
    Sep 14, 2006
    4,882
    6
    I don't think he said "shock cooling" is a myth, it's just not as big a deal as many people think. You really have to work to damage the engine in this way. Even an iconoclast like Deakin doesn't think shock cooling is a total myth.
  17. Patrick
    Patrick Well-Known Member
    Nov 22, 2006
    1,848
    245
    Or the fact that in every other circle where internal combustion piston engines are used its called "manifold vacuum" or "boost" (in a forced induction engine) and is typically calibrated in either PSI or BAR.
  18. USMCmech
    May 3, 2004
    4,852
    1,824
    Yeah, I agree that is possible to dammage an aircooled engine by cooling it to fast. However the conditions required to make that happen are WAY outside normal operations. As I said, skydiving 182s run reliably in most cases for plenty of hours, and they are probably the most at risk for this problem. Your basic take off, cruise for two hours, descend, and land pilot will never be in danger of "shock cooling" (unless something is drasticly out of sorts).
    Airflow is the main variable for engine cooling, power is second. As long as your airspeed and cowl flaps remain constant, CHTs will change only gradually even with large power changes.
    If your CHTs are below 350, then the engine is already "cool", and you can do whatever you want.
    350-400, make a modest power reduction giving a constant airspeed 500 FPM descent, and you'll be fine.
    400-450, slightly open your cowl flaps, and/or adjust the mixture 2-3 minutes before descent. Then when you land, find a mechanic to investigate why your engine is running so hot.
    Exceptions are out there, but those guidlines will keep 95% of engines happy for decades.
  19. ctab5060X
    May 25, 2007
    4,998
    1,544
    I would venture to say shock cooling is more of a "pseudo-myth" than just a myth. It does exist and you can damage an engine by cooling it too rapidly, but not to the extent that some individuals would want you to believe.
    Not sure about other manufacturers, but Lycoming recommends CHT changes of not more than 50 degrees per minute during descent. Looking at it that way, you almost need one of those "one in a million" days where everything necessary for shock cooling to happen is prevalent. Even in the middle of the winter in KC, we normally wouldn't see CHT changes of 50 degrees per minute in the Commander.
  20. tgrayson
    tgrayson New Member
    Sep 14, 2006
    4,882
    6
    For what it's worth, Deakin, et al, think this recommendation is way too conservative.
Share This Page
