  2. Dear Visitor, registration is absolutely FREE!
    You can also start your membership quickly by using the "Login with Facebook" for fast registration!
    Get access to our live chat, members-only jobs section and more, today!
E190 poor design
Discussion in 'General Topics' started by scooter2525, Apr 22, 2012.
  1. ChasenSFO Gooby pls!
    Jan 15, 2008
    Message Count:
    4,248
    327
    *ding*
    THUMP CRASH BAM OMG!
    *silence*
  2. Autothrust Blue Put your hat on.
    Aug 3, 2010
    Message Count:
    7,611
    1,283
    Since the airplane is derisively called many things involving food (ironically most of it Latin American as opposed to south American), that fits I suppose.
    Actually, I like the noises the 145 makes. You can tell things are happening. The PTU on the Airbus 320 series is far more obnoxious than most anything the airplane makes.
    Sent from Seat 3D
  3. Houston Well-Known Member
    Dec 24, 2008
    Message Count:
    1,000
    267
    14 CFR 91.209(b)
  4. Dan208B Well-Known Member
    Mar 8, 2008
    Message Count:
    372
    29
    Which says "No person may: (b) Operate an aircraft that is equipped with an anticollision light system, unless it has lighted anticollision lights. However, the anticollision lights need not be lighted when the pilot-in-command determines that, because of operating conditions, it would be in the interest of safety to turn the lights off."
    Polar mentioned that you can see the strobe lights in the cockpit also and this is true. And on a long dark night, they get pretty distracting. So to me, this is in the interest of safety. On that note, the airplane also has flashing beacon lights on the top and bottom of the fuselage which are technically anti-collision lights, so if they are on and operating you really aren't in violation of 91.209(b).
    ProudPilot likes this.
  5. Dan208B Well-Known Member
    Mar 8, 2008
    Message Count:
    372
    29
    I used to fly Cessna 402s in a previous life. Great airplanes. The B models had rotating beacon lights on the tail. The C models did not (never understood this as the C was supposed to be an improvement). A lot of people used to quote 91.209(b) in regards to starting the engines and taxiing out at night with the wingtip strobe lights running. And I always argued the second part of the reg, because I think running the strobe lights on the ground at night is a distraction to you as well as other aircraft, and that's obviously a safety issue. I recently rode on Cape Air and I see they have added beacon lights to the bottom of their 402s, great idea.
  6. Autothrust Blue Put your hat on.
    Aug 3, 2010
    Message Count:
    7,611
    1,283
    The beacon counts.
  7. N519AT Ahh! This is how I change this!
    Aug 28, 2003
    Message Count:
    2,815
    191
    Yup. I flew a Piper Archer for a while and all it had was landing lights, nav lights and strobe lights. At night all I used to run until I took the runway or crossed a runway was the nav lights. No one ever said anything to me about it.
    When I worked the ramp I used to love the guys that would come in at night with all of the lights on and blazing, blinding everyone in sight. From my experience that was more way dangerous than just running the nav lights. If aircraft manufacturers were just a little bit less cheap and just put a beacon on the tail that would solve a lot of problems.
  8. Autothrust Blue Put your hat on.
    Aug 3, 2010
    Message Count:
    7,611
    1,283
    Too, the beacon is the universal signal for "I am starting or I am running," whereas strobes mean something else entirely.
  9. Houston Well-Known Member
    Dec 24, 2008
    Message Count:
    1,000
    267
    Can you site anything other than opinion to support that statement?
  10. Dan208B Well-Known Member
    Mar 8, 2008
    Message Count:
    372
    29
    Yes. The MEL for the airplane uses the wording "Red Anti-Collision lights." Nobody is going to question that in a real-life situation. If you're concerned about it and have a fed on board, ask them what they think before you do it, that's usually a good solution.
  11. Houston Well-Known Member
    Dec 24, 2008
    Message Count:
    1,000
    267
    What type aircraft, and is your MEL more or less a copy of the MMEL?
  12. BobDDuck Looking for my moving clouds again...
    Sep 19, 2003
    Message Count:
    10,142
    617
    One the CRJ we can MEL all three (wingtip, wingtip, tail) strobe lights, as long as the flight is only operated during daylight hours. We can MEL only one of the two red beacon lights.
  13. Dan208B Well-Known Member
    Mar 8, 2008
    Message Count:
    372
    29
    Embraer 170/190. I'm not sure about the MMEL. But on that note, the FARs have no definition for "anti-collision light." In my personal opinion that would be beacons and strobes. Would you agree? It could be the opinion of the individual inspector you're dealing with.
    That brings to mind the 737. On the overhead panel, the beacon light switch is labeled "anti-collision."
  14. Firebird2XC Who Dares, Wins.
    Mar 9, 2007
    Message Count:
    9,046
    137
    What else do they entirely otherwise mean?
    You know what you do when you have to MEL the beacon system, right? Turn on the strobes. Derp.
  15. MikeD Administrator
    Feb 26, 2003
    Message Count:
    29,069
    1,706
    Shack. For start, if red beacon isn't working, and all there are remaining onboard are "day" strobes (white); then having those on at night is a distraction and safety hazard. Position lights on, and a taxi light on if you like, are sufficient. If equipped with "night" strobes (red), usually in place of a rotating beacon, those can safely be used without blinding everyone else on the ramp from persons, to drivers, to pilots.
    In terms of turning off day strobes in IMC, when they're a distraction to the cockpit, comes under the heading of "judgement" that pilots are paid and certificated to exercise. And turning them off for safety reasons in that situation is perfectly valid. Besides, who's going to see you in IMC anyway?
    On a related note, flying in formation(s) at night, the lead aircraft never has his strobe lighting on. Because it's a safety hazard to the trail aircraft, not only when "unaided", but under NVGs too.
    If they're day strobes, that could be a problem. And usually is.
  16. Seggy Well-Known Member
    Jan 22, 2004
    Message Count:
    8,815
    777
    You guys mean the E-180s?
    Nark likes this.
  17. Bandit_Driver Gold Member
    Oct 31, 2003
    Message Count:
    5,225
    151
    Heck the strobes have been removed and deactivated on the majority fo the 727's I have seen. The Red beacon satisfies the reg.
    One think I can't stand are the GA aircraft that taxi around with the stobes and all the landing lights on.
  18. MikeD Administrator
    Feb 26, 2003
    Message Count:
    29,069
    1,706
    You 727 guys are obviously dangerous and a hazard to everything else around you up there; birds included.
  19. Bandit_Driver Gold Member
    Oct 31, 2003
    Message Count:
    5,225
    151
  20. Nick Well-Known Member
    Jul 17, 2003
    Message Count:
    4,335
    172
    Yeah, half of my reserve flying this month has been covering the first leg or two of a commuter's trip while they attempt to meet the trip near the end of the first workday after not being able to get to base. The other half has been repositioning empty E-180s back to where they need to be after they've been looked at by maintenance for several days after doing, well, their 180, if they even made it to pushback before the "ding!"
Share This Page
