  2. Dear Visitor, registration is absolutely FREE!
    You can also start your membership quickly by using the "Login with Facebook" for fast registration!
    Get access to our live chat, members-only jobs section and more, today!
Do employers use flightaware to verify flights in logbooks?
Discussion in 'Interview Experiences' started by AG3FLY, Feb 20, 2009.
  1. MikeOH58 Well-Known Member
    Dec 5, 2005
    Message Count:
    2,500
    83
    Re: Do employers use flightaware to verify flights in logboo
    Yes, you are screwed.
  2. Boris Badenov Sapping and Impurifying.
    Jul 26, 2007
    Message Count:
    10,883
    2,324
    They do. If you think coming up with all of that P51 time was difficult, try figuring out what to erase! D'oh! :laff:
  3. ppragman Slow Plane, Fast Plane
    Sep 15, 2007
    Message Count:
    6,728
    401
    What I heard from an old timer is that "you can't really get away with more than 10% of what your total time is, which doesn't really help you any, so don't bother."
    That's not to say it isn't done.
  4. Patrick Well-Known Member
    Nov 22, 2006
    Message Count:
    1,446
    63
    I've heard discussions pertaining to and actually been asked essentially how to Parker P-51 a logbook. I've heard comments ranging from taxing the aircraft around to leaving the country for a year and miraculously coming back with an extra 1000 hours to sitting in the jumpseat on an airliner and logging that time. I have no doubt that there are others.
    What is really comes down to, to me, is that it's going to be pretty obvious (unless you're the next Buzz Aldrin) that if you put down 1000 hours of total flight time on an application, yet you only have 300, and you then get selected for an interview, that between the interview and the sim session it's going to be glaringly obvious that you don't have the experience that comes with 1000 hours. For this reason, I would agree that one could conceivably get away with pencil whipping an extra 10% of flight time in there, but for the little difference that would make, why bother?
    As to the idea of using flight aware to verify flight times, I think that would highly depend upon the type of flight time that one was looking to verify. Any VFR flight training will not show up on flight aware, so that doesn't work. If one is looking to verify flight time at a previous 121 or 135 opertation, it is far easier to simply ask the previous company than to run the various tail #'s of aircraft that the applicant claims to have flown. Now yes, if in the previous 3 weeks to an interview an applicant claims to have flown 50 hours of cross country time in a twin, and one twin at that, that could easily be checked.
  5. texas_pilot Well-Known Member
    Sep 26, 2006
    Message Count:
    1,199
    4
    I asked this on another thread and never saw the answer
    Does experimental time count to TT?
    I don't mean powered chutes, but would RV4 time for instance count?:dunno:
  6. OldTownPilot Well-Known Member
    May 3, 2005
    Message Count:
    4,862
    9
    Yes.
    The only thing that doesn't count is part 103 ultralights.
    Single seat, 254 lbs empty, 5 gal, 26 mph stall etc.
  7. n6149s New Member
    Jun 16, 2009
    Message Count:
    108
    0
    I will fly vfr training flights and they will show up as 7 minute flights. If you leave a class c or d airport for vfr instance, your flight will show when radar picks up your transponder. If you fly to another airport for traffic pattern work and cancel services, your flight on flightaware "ends". So a 7 minute flight on flightaware was actually 2 hours
  8. rd757 Well-Known Member
    Feb 2, 2009
    Message Count:
    2,147
    84
    VFR will only pop up when you pick up Flight Following, if the controller makes up a flight plan for you. If they just created a flight strip but no flight plan, it will not pop up.
    RD
  9. PA44-LUV Well-Known Member
    Jun 23, 2009
    Message Count:
    263
    0
    That's why I would backup hard-copy logbooks with electronic ones that automatically do the calculations and breakdowns. I spent 10 hours converting my logbook to an electronic copy and can't tell you the number of simple math errors I found when I did a line-by-line audit of my logbook.
  10. SpiraMirabilis Possible Subversive
    Jun 18, 2006
    Message Count:
    8,159
    568
    If employers have such a concern that you may be padding your logbook that they would want to verify anything with anything in this environment they will just not hire you and move on to the other 50 applicants they have in the stack.
    RV4 time definitely counts, its more of an airplane than many!
  11. planestupid New Member
    May 21, 2009
    Message Count:
    50
    0
    Here is something else to think about. With the advent of flightaware, it would not be hard for someone to pad their logbook with time in an aircraft that has actually flown.
    Track an aircraft, log the time. Not too difficult.
    But the question is this: Why in the world would anyone do this?
    For the life of me there is absolutely no good reason or motivation to falsify your times. Not even a job nor interview.
  12. MOONWOLF Well-Known Member
    Jul 14, 2009
    Message Count:
    384
    21
    They would only be able to look up IFR flights though...right? So if you don't file IFR then nothing shows up on record.
    My thinking it would be pointless for them, unless they wanted to know how many times you've flown ifr.
  13. TheresaPilot Well-Known Member
    Dec 4, 2008
    Message Count:
    1,088
    0
    It's any flight that gets a squawk code.
  14. mikecweb Well-Known Member
    Oct 14, 2005
    Message Count:
    6,528
    1,234
    Not always.
    Nice hair btw....
  15. gatorbuc99 Well-Known Member
    Oct 8, 2008
    Message Count:
    65
    0
    From what i understand it's any flight that gets a "real" code...one that doesn't start with a 0, like you'd get from an approach facility for a short flight, or a code you get from center, i think that's the deal-io
  16. germb747 Well-Known Member
    Jan 2, 2008
    Message Count:
    1,509
    2
    I recommend people just take care to ensure their flight times are 100% legit and as close to 100% accurate as possible. Then, there's no need to worry about what means, if any, a potential employer may use to validate the times in your logbook.
  17. Alinator New Member
    Aug 10, 2008
    Message Count:
    91
    0
    I think it sucks if prospected employers actually verify log books. I now have to go back and remove my B-777 type and subsequent PIC time. And to think, I was this close to getting hired on at one of dem' top-notch Nigerian operations! Good thing I have a backup plan for employment over there... :yar:
  18. aloft Suspended
    Sep 5, 2001
    Message Count:
    9,002
    1
    Again, not always.
    Military and other public use flights are blocked, as are many civilian corporate operators who claim it's for "security" reasons (like not letting shareholders see how many trips to Aspen or Hawaii a company's jet makes).
  19. rd757 Well-Known Member
    Feb 2, 2009
    Message Count:
    2,147
    84
    Bingo. That is the main reason a lot of corporate jets are blocked, which makes a spotters job difficult :(
    RD
  20. mikecweb Well-Known Member
    Oct 14, 2005
    Message Count:
    6,528
    1,234
    If it saves corporate jet jobs who gives a ?
    Why won't this ridiculous thread die?
Share This Page
