  2. Dear Visitor, registration is absolutely FREE!
    You can also start your membership quickly by using the "Login with Facebook" for fast registration!
    Get access to our live chat, members-only jobs section and more, today!
  3. Watch Jeopardy tomorrow night and cheer on Mike Lewis! (Moderator)
Dash speed brakes
Discussion in 'Technical Talk' started by JordanD, Feb 10, 2012.
  1. JordanD Sizeable Member
    Nov 20, 2007
    Message Count:
    4,531
    984
    Just a quick question for the Dash guys. Why are the speed brakes always up on the taxi? It seems like they dont stow them until ready for the takeoff roll a lot of times. Is it connected with the prop pitch used for taxi somehow?
  2. OhioStatePilot Well-Known Member
    Feb 21, 2009
    Message Count:
    1,820
    0
    Connected to PL angle and WOW.
  3. SurferLucas Southern Gentleman
    Jun 5, 2008
    Message Count:
    3,228
    388
    The Q400 has a "Flight/Taxi" switch that arms the spoilers. We select to "Flight" when cleared onto the runway for departure and they retract at appox 50% of power lever movement (if I'm recalling my systems correctly). Upon landing they deploy when the WOW switch is triggered, and then they retract again when we select "Taxi" during the after landing flow.
  4. C150J Well-Known Member
    Feb 2, 2004
    Message Count:
    1,935
    17
    Very similar system in the G-IV.
  5. SurferLucas Southern Gentleman
    Jun 5, 2008
    Message Count:
    3,228
    388
    Quit braggin! :)
  6. C150J Well-Known Member
    Feb 2, 2004
    Message Count:
    1,935
    17
    I'd wager to say that your equipment hand-flies far, far better than a Gulfstream. It's a capable aircraft, but handles like a truck.
  7. Rocketman99 Well-Known Member
    Jul 7, 2005
    Message Count:
    2,220
    159
    I'd wager against that. The Dash flies like an absolute piece of poorly designed crap. Which is what it happens to be.
    The interesting thing is that the flight/taxi switch in the spoilers is magnetically held down in taxi and when you push up the power levers the switch automagically flips back into the flight position. Which begs the question, why the hell do we move the switch ourselves if it's going to flip itself anyway if(when) we forget. Sort of like the main bus tie...
  8. SurferLucas Southern Gentleman
    Jun 5, 2008
    Message Count:
    3,228
    388
    The Q400 flies like a dumptruck...and I find it's pretty difficult to hand fly once the FA's get up and start moving around. Depending on the "size" of the FA's, it can be 500lbs moving back and forth.
    We have some Captains that will push the power levers up quickly while taxiing onto the runway...def not SOP, but gets the job done.
    The reason why have to do that Mr. Rocketman, is because our plane was designed by canadians...and french ones at that...question = answered!
  9. Rocketman99 Well-Known Member
    Jul 7, 2005
    Message Count:
    2,220
    159
    Well played Sir!
  10. syntrikz Well-Known Member
    Nov 1, 2009
    Message Count:
    481
    57
    Alt sel is jerk too....
  11. cmhumphr Well-Known Member
    Aug 8, 2010
    Message Count:
    1,135
    127
    Piedmont's spoilers deploy on landing too, but ours don't? Could never figure that out.
  12. SurferLucas Southern Gentleman
    Jun 5, 2008
    Message Count:
    3,228
    388
    I agree with this statement...every time I hear a chime, I instinctively say "1 to go, Atl Select"
  13. syntrikz Well-Known Member
    Nov 1, 2009
    Message Count:
    481
    57
    haha... we roll in "dirt" which is field elevation rounded up to next hundred, I catch my self saying that all the time at 1000 AFE
  14. SurferLucas Southern Gentleman
    Jun 5, 2008
    Message Count:
    3,228
    388
    We do the same thing..."dirt alert" or "You're gettin muddy".
  15. N519AT Ahh! This is how I change this!
    Aug 28, 2003
    Message Count:
    2,815
    191
    I think only the 100s and 400s deploy their roll spoilers as speed brakes on touchdown.
    This post brought to you by beta from my iPhone.
  16. RightSeatGirl KA'PLAH BITCHES!
    Dec 8, 2007
    Message Count:
    1,847
    117
    Most of the 300's and 200's have the ground spoilers deactivated or not installed. The original intent of the system, and the reason why they are painted red is so the crew could do a visual check for the accumulation of snow/ice prior to take off. It was one of those cool yet redundant toys that some genius at Bombardier decided needed to go back on the Dash in the 400 incarnation. As if there aren't enough systems that actually have a useful purpose on the damn plane to worry about...
  17. milleR Well-Known Member
    Mar 11, 2008
    Message Count:
    757
    136
    lol what? How much time do you have in the Dash?
    The 8-100's had the same spoiler setup as the STOL designed Dash 7, since that's what the plane was based off of. Because the Dash 8 couldn't meet the stol performance of the -7, when they designed the 8-200 and -300 series they did away with the system. The Q-400 is a totally different beast, despite the same type. Spoilers are needed both for braking and roll control since it's substantially larger and heavier than the previous aircraft.
    Edit: never seen a dash that wasn't painted white, blue, black, or gray.
  18. jynxyjoe The Kickin' Chicken!
    Oct 31, 2007
    Message Count:
    2,389
    384
    I'll tell you this much, taxing around with them spoilers up is unsafe!
    Dey dook owr JAWBS!
  19. milleR Well-Known Member
    Mar 11, 2008
    Message Count:
    757
    136
    Come back to the props man, the water's nice
  20. Cessnaflyer Concessions? I have nothing to concede!
    Dec 9, 2006
    Message Count:
    4,921
    458
    The q's at qx have red panels
Share This Page
