CRJ V1 cuts !
Discussion in 'Airline Pilots' started by This is My Screen Name, Feb 23, 2017.
  1. This is My Screen Name
    This is My Screen Name Well-Known Member
    Feb 23, 2017
    10
    8
    Exactly.
    5 min prior in the sim my engine failed on takeoff, the Cap'n went comatose and now my APU is on fire!
    :D
  2. mrivc211
    mrivc211 Well-Known Member
    Sep 27, 2000
    3,679
    565
    "It's a non-event in the RJ"
    Most spoken words of EMB-120 pilots transitioning to the RJ early 2000's.
    Autothrust Blue and Roger Roger like this.
  3. BigZ
    BigZ Well-Known Member
    Nov 19, 2007
    230
    171
    I used to drive an Ultra with a former US Airways captain
    "Heading"
    "Heading"
    "NAV available"
    "NAV"
    "NAV"
    Build a pyramid and cross the Nile kind of guy.
    Then I flew a CJ2+ with a private rated owner in the left seat.
    "Positive rate"
    "Huh?"
    "Positive rate. Gear up?"
    "Oh, yes, please"
    "Four hundred"
    "Huh?"
    "Flaps coming up..."
    Second job paid moar moneys
    guywhoflies likes this.
  4. Autothrust Blue
    Autothrust Blue "We cannot afford it."
    Aug 3, 2010
    16,688
    9,738
    Wholly accurate
    mrivc211 likes this.
  5. PhilosopherPilot
    PhilosopherPilot Well-Known Member
    Jul 24, 2003
    3,072
    2,443
    If you're getting that, you have a marginal instructor. I'm nearly silent during any training until it is time to talk. (Or unless something BIG happens that needs immediate correcting.)
    Sure, there are times to talk during a maneuver, but those are generally less frequent than some instructors think. Most trainees cannot listen and think and fly all at the same time. Not at first anyway.
    Anywho, sorry you had that experience.
    Autothrust Blue likes this.
  6. Crop Duster
    Crop Duster UNSUB
    Mar 25, 2013
    2,630
    2,230
    Before I became a pilot, I couldn't even spell FMA!!
    Screaming_Emu likes this.
  7. Crop Duster
    Crop Duster UNSUB
    Mar 25, 2013
    2,630
    2,230
    I think you are being very kind and diplomatic. Well done! ... That instructor can eat my shorts.
  8. Crop Duster
    Crop Duster UNSUB
    Mar 25, 2013
    2,630
    2,230
    That's 'cause most Bro drivers have real world experience with those pesky engine failures. Jet jocks get no props from Bro Bros.
  9. BobDDuck
    BobDDuck Gone whale watching...
    Sep 19, 2003
    14,335
    8,324
    I've had (proportionally to total time in each) more engine failures in a jet than in a prop (turbine and piston combined).
  10. Autothrust Blue
    Aug 3, 2010
    16,688
    9,738
    I've had more engine control problems in the CRJ than in any other aircraft I've flown; I never had so much as a hiccup out of the Pratts on the Brasilia, and in the short time I've been on the CRJ I've had (for whatever reason) several unscheduled APR activations.
    "That's cool, I guess."
  11. trafficinsight
    trafficinsight Well-Known Member
    May 8, 2007
    4,262
    1,979
    3 engine failures in my first 1500 hours, not a single one in my second 1500.
    I think it's just sort of luck and exposure.
  12. Screaming_Emu
    Screaming_Emu My friend Martin said...
    May 29, 2002
    14,028
    14,924
    That's weird as the engines are the only thing I didn't have a problem with on the CRJ. Even when they mounted a new one and didn't put oil in it.
  13. Autothrust Blue
    Aug 3, 2010
    16,688
    9,738
    I'm pretty sure the specific issues I've had are not the fault of GE's fine power plant, but the equipment it is mated to.
    Would like to hear the oil story.
  14. Screaming_Emu
    May 29, 2002
    14,028
    14,924
    Mounted a new (or maybe just different?) engine in BDL. It flew to ORD where I got it. Flew (with no autopilot) from ORD-SAV. About half way we noticed the oil pressure was in the green, but bouncing all over the place. Ran QRH, no change. Conferred with the company, they said press on.
    Land in SAV, contract MX comes out and puts a reasonable amount of oil in it, still shows empty. No evidence of leaks, so they put a fornication ton more in until it's topped off. Quick engine run and then it was off to ORD.
    I guess it's shipped with a certain amount still in it, engine DGAF and ran anyway.
    killbilly likes this.
  15. Autothrust Blue
    Aug 3, 2010
    16,688
    9,738
    Huh, interesting.
    Impressive even.
  16. Cptnchia
    Cptnchia Well-Known Member
    May 16, 2007
    7,391
    8,113
    Keep in mind that the core engine is basically the same one that is mounted on the A-10, just super derated. That thing can take a direct hit of AAA, and keep on, keeping on, so to speak.
  17. BobDDuck
    Sep 19, 2003
    14,335
    8,324
    The CF34 is a beast, and like Emu said, the engines were always the least of my issues on that plane. Still had two of them go, but one was fod (I guess a common mallard duck is bigger than a piece of AAA) and the other was a MX screwup. I've had one BR715 toss a turbine blade (which apparently RR had never seen before), but otherwise it's been a solid engine, especially considering how we run them.
  18. mrivc211
    Sep 27, 2000
    3,679
    565
    EEC failure was one that caught me with my pants down. "Engine failure!!!"
  19. tcco94
    tcco94 Professional GTA V Pilot
    Feb 16, 2015
    1,599
    999
    Don't expect your IOE to be tons of ILS's....mine consisted of arcs, holds, VOR, GPS, LOC, LOC BC approaches. Only did ILS approaches into bigger terminal airports.
    Of course on the line might be different.
  20. Autothrust Blue
    Aug 3, 2010
    16,688
    9,738
    I think I did one or two ILS's on IOE. I did a bunch of RNAV approaches. Including a procedure turn, oddly enough in TYOOL 2017.
    tcco94 likes this.
Share This Page
